Question about Frigidaire FRT18S6AW Top Freezer Refrigerator
Gurgling noise for about 5 seconds when closing freezer door or refrigerator door
    Problem Solver:
  • 5 Answers
See tis for sources of noise:
http://www.applianceaid.com/images/fridgenoises.JPG
Posted on Feb 16, 2010
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
May 17, 2010 | Freezers
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Making loud gurgling sounds only when door is closed. Have called for service but 5 days away and this is constant
the loud noise come from the fan in the back of your freezer unit , but if you not expert i wouldent open the unit b/c Fisher and Pyk are very sensative units and if you do something wrong or put something wrong they wont work.
the noice is the fan that might be bad or tuch something like ice...
hop it will help you
Jan 08, 2010 | Fisher and Paykel Active Smart E522B...
When I open and close the freezer door there is a gurgling sound
The gurgling sound , is the vacuum being pulled thru the defrost drain line . Like when you close a freezer door , and you see the gasket being pulled in tighter . This gurgling , is the drain p trap with a vacuum being pulled thru it . Normal .
Sep 25, 2009 | Kenmore Refrigerators
Refrigerator gurling noise when door closes
There is a water evaporation tray in the back of the frig. Air pressure fron closing door makes air bubble thru tray. Its not a problem.
Aug 28, 2009 | Frigidaire FRS26R4A Side by Side...
My refrigerator gurgles when the bottom freezer door is closed?
Air is stabilizing between the fridge and freezer.
Do not worry.
Mar 11, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Gurgling noise
gurgling noises are not unusual - after all there is a gas/liquid mixture being circulated
Sep 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Frigidaire FRT18S6AW Top Freezer Refrigerator Logo
640 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
