Question about Panasonic KX-T7885 Cordless Phone
I have a Panasonic KX-TD816 system with multiple lines and one KX-T7885 900 MHz wireless handset. The handset no longer works and I have purchased two used handset replacements, will these units work with the existing wireless base from the original handset.
  • darzt Jan 31, 2010
    My replacement handsets do not work so you are saying that each handset and wireless base are programmed for each other and are not interchangeable. Is there any other way for me to add wireless sets to this system?
  • 2,069 Answers
Check here page 154 for wireless installation guide on your unit. Regards
Posted on Feb 01, 2010
  • 547 Answers
Generally speaking the answer is no -- even within the same model year, manufacturers will update firmware revisions multiple times, and they aren't always backwards compatible.
That said, you did say "I have purchased" so you have nothing to lose by trying. Charge up the replacement handset using the base station (not an axillary charger) and if it is compatible, then it should synchronize with the base station's radio.
Posted on Jan 31, 2010
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
User Manuel for panasonice cordless phone kztgea20
Do you mean the KX-TGEA20 cordless handset? I don't know of any KZ models in the Panasonic product line. If you do have the KX-TGEA20 handset, then Panasonic has the manual here: ftp://ftp.panasonic.com/telephone/om/kx-tgea20_en_om.pdf . You can also find the manual on the product page, http://shop.panasonic.com/search?q=KX-TGEA20# . Select the S or B suffix depending on the country in which you use the phone.
If you need additional information on using the handset, check the manual for the base system. The KX-TGEA20 works with the KX-TGE210 and other models. The KX-TGE210B manual is available here: http://shop.panasonic.com/support-only/KX-TGE210B.html . The direct link is ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf .
I hope this helps.
Aug 02, 2016 | Panasonic Lands Phones
Panasonic KX TD816 KX-T7433 can receive 2 calls but cannot dial out
Are the the two lines each plugged in a separate CO Line port?
Feb 07, 2013 | Panasonic KX-T7433B Corded Phone
How do we make internal calls with Panasonic KX-T7433 handsets?
By default, Panasonic numbering is 101-164 and 201-264. The Intercom gives you dial tone and you dial the 3 digit extension number. Dial 0 should ring extension 101. Normal digital phones start at 101-116 on a TD816/1232 cabinet.
Carl
Jul 13, 2011 | Panasonic KX-T7433B Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
Panasonic KX-T7885 Cordless Phone Logo
80 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
