Question about MSI 845GLMS-L (MS-6754G-020) Motherboard
MSI - 845GLMS (MS-6754) powers off
I recently purchased a replacement for a friend and cannot get a boot, locks on blue screen 0x0000007b, yada yada, tried different power supply, different RAM, different HD's, no luck please help
  • JaredSims Feb 18, 2008
    i can't get the xp startup cd to finish because it powers off with out notice if do the boot from cd, but i can leave it on as long as i like, as long as i'm not doing the install. (example the bios menu, or flopp boot to A:)
    President:
  • 2,351 Answers
Http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=522
Link to board.
Manual: http://global.msi.com.tw/index.php?func=downloadfile&dno=3640&type=manual
This error message may occur if the primary disk group identity of the hard disk does not match the primary disk group identity that is stored in the registry. There wasn't anything wrong with your memory or PSU. (not the cause for blue screen).
If there is data on the primary drive than slave it into another system & copy the data to another drive or CD. The most common data to copy. My Documents, Favorits, Desktop. Users name(jeff), open Application Data, copy Identities. open Mocrosoft, copy Address Book.
What is needed is a fresh install of windows. You can either boot to windows through the cdrom & quick format before install or use the hard drive's utility disk software or CD/iso bootable's to redo the drive. I understand this is a replacement board & one would think that re-connecting everything the system should just boot but from time to time widows gets trashed in the prosses. Though the quick formatt is faster I prefer to use the Mfg's bootable ISO to make a bootable CD. Here you can also check the drive & MBR & pick size & even FAT type.
The choice's are up to you. Just make sure the bios is seeing the drive correctly.
Posted on Feb 18, 2008
  • Mike Peluso
    Mike Peluso Feb 19, 2008
    When the system is runnng like you mentioned, no computing power is needed. When doing an install of say Windows the CPU is working like a dog. If your CPU overheats it's going to shut down the system. Did you check the pins on the CPU & make sure there where no pins bent before installing into the socket?
    When you put in this replacment board did you clean the CPU & heatsink from old thermal grease (Using Alcohol)? Did you check the heatsink for deep scratches (can cause exessive heat), & clean the heatsink's fins & CPU fan? Did you add new thermal grease to the heat sink? Lastly there is a 4-Pin ATX-12v connector on the board, loacted just behind the PS2 keyboard & mouse. That suppllies power for CPU. The 20 pin main ATX does not have enough power to support the CPU. This has nothing to do with your blue screen from before.
I need the manual for my motherboard ...o factory name on the board ..just ms 6745 ver 1.0
The manual and updated drivers for your board is in this link....
http://www.msi.com/product/mb/845GLMS.html
A thank you reply will be appreciated!
Hope that helps you out.
Thanks for asking FixYa!
Jul 30, 2011 | MSI 845GLMS-L (MS-6754G-020) Motherboard
I can't load my boot menu .. What should i do? i need to boot from flash device but i ca't
What kind of keyboard do you use, wireless or PS2? Do you get any message? Does the del key works?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jul 17, 2010 | MSI 845GLMS-L (MS-6754G-020) Motherboard
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
MSI MS-6754 mother board won't boot and beeps when I swap processors
your motherboard has the chipset of 845GL series
so the specification of your motherboard is as follows read it carefully there may be some error in the manual or it might not be your motherboard model just have a check with that . here are the specifications as per i saw in the net ...
CPU • Support Intel® P4 (Socket 478) processor up to 2.6 GHz. Chipset • Intel® 845GL Chipset - Support FSB 400 MHz. - Integrated 3D/2D graphic core (Core frequency= 200MHz, 350MHz integrated 24-bit RAMDAC). - Support PC266/133 Technology. • Intel® ICH4 Chipset - AC'97 Controller Integrated. - 6 ports Hi-Speed USB 2.0 controller, 480Mb/sec. - Support both ACPI and legacy APM power management. - Legacy free support.
Sep 06, 2008 | Computers & Internet
MSI kt4v minus 5v (-5v)
replace the mother board capacitor its 1500uf / 6.3 v
May 08, 2008 | MSI KT4V (MS-6712) Motherboard
Will not post
yaa this type of beep means your RAM is missing.
to confirm this, just remove your RAM and boot, you will find the same beep.
if this the your case, try thsese:
1...clean the RAN connection point, and insert it again, then try too boot. if not.
2....change the RAM in another slot and try to boot,
if no luck then, change the RAM..
Thanks
Iqbal
Mar 25, 2008 | MSI 845GLMS-L (MS-6754G-020) Motherboard
Cannot fix partion error
It sounds like its overheating or has bad hardware on the mainboard.
Look at the Capacitors ( the cylinderers with flat tops sticking up from the board) They should have flat tops, if there domed or have crud on top, then they have gone bad and the system will eventually quit altogether. get a new mobo. If you say that the Hard drive is proven good, then its the mainboard.
Feb 18, 2008 | MSI 845GLMS-L (MS-6754G-020) Motherboard
MSI 845GLMS-L (MS-6754G-020) Motherboard Logo
751 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
