Question about Samsung DVD-VR320 DVD Recorder/VCR
Problems connecting dvd player to dynex tv.
Problems connecting Samsung dvd player to Dynex tv. Keep getting a "no signal" response on the tv screen. Using av cables (red, white and yellow) to connect the two devices.
  • 1043 Answers
SOURCE: Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
Posted on Aug 12, 2009
SOURCE: Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Posted on Jul 02, 2009
  • 11800 Answers
SOURCE: I have purchased a Samsung Series 4 LCD TV.
Most likely ther's something wrong in the settings - this happens when you get a Composite ( yellow)signal in a Component (yellow+ blue+red) connection.
First of all make sure you have selected the correct plugs on both the tv and the dvd - the yellow/video composite + red/right + white/left should be in their own separate box. Then check that the cable is correctly plugged in. Finally check that the tv is set to use the Composite, not Component AV entry.
Posted on Aug 28, 2010
  • 95 Answers
SOURCE: I just got my DVD-VR375. I want to watch a rented
If you have the original remote for the TV there should be a button that says Input or I Select or something similar. You need to change your "Input" to L1 or L2 or AV, or something similar.
Posted on Dec 05, 2009
SOURCE: No VHS playback between DVD/VCR Unit and LCD TV (Both Samsung)
I am having the exact same problem....can anyone help?
Posted on Mar 22, 2010
My tv is having gray and white strips going from top to bottom and it does it constantly every few seconds and does it when it's on the DVD player and the regular tv. It is a dynex brand.
Remove all externally connected devices so only the TV is plugged in, this includes the cable tv connection or external antenna. If the lines are still there, then it is in the circuitry of the TV. If not, add one item at a time and let the TV run for a while, keep adding connections until the lines show up. If you TV is the culprit you have four options:
1. Check to see if there is a firmware upgrade and install it. Check your owners manual.
2. Contact a TV repair shop and get an estimate - usually close to or as much as a new TV.
3. Live with the lines.
4. Replace the TV with a more reliable brand. This doesn't guarantee you won't have problems, but your chances of having them will greatly diminish. Samsung, Sony and Panasonic come to mind. Dynex, I won't even look at.
That's 21 years as an electronics tech.
Sincerely,
mpkramer
May 23, 2014 | Televison & Video
Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black Logo Print Email Problem with Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black I have a Dynex Bluray Player and when I connect it with AV Cab
If the item is under warranty return it asp. The problem is in the power supply, the cause is a open capacitor sometimes leaving a bulge at the top.
Apr 25, 2012 | Olympus Televison & Video
Hi, I have a Dynex flat screen and I want to play a video. I connected the RCA cables. What do I need to do?
Hi If you have connected the RCA cables corretly, that is, Yellow, Red, and White colured sockets of video source component, may be a VCR, DVD, Blu-Ray etc; to the respective colured sockets to the TV, just switch ON both the devices, insert a video casette, CD or DVD whatever it may be into the source player. Get into the Menu of TV, surf through; and come towards its Input option and select the input you want to get through it. Hilight that option and press enter button on the remote control. When the correct input have been selected you will see the video signals plays through your TV. OK.
Jul 11, 2011 | Dynex Televison & Video
I connected dvd player to dynex 32 inch tv. what
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
Jan 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Yah i have a dynex tv and a Asus desktop comp and my tv says no signal when i plug it in i dont know what the problem is
Is the dynex tv unit installed inside the ASUS desktop computer?
The TV receiver needs an antenna/aerial connected to the TV receiver to receive TV signals, without it you will get no or weak signal.
Have you connected an antenna/aerial to the Dynex TV unit?
Jul 22, 2009 | ASUS Computers & Internet
Dynex and Samsung
A common problem with these "all in one units"
When you have a DVD playing it is a digital signal direct to the processor.
When you have an external source ie: TV etc it may be a digital source, but you have to tell the Samsung unit this.
Make sure when it is on the TV setting (Aux) or whatever input you have chosen is in Dolby Digital or similar, Not stereo.
The unit should have a setting for this called sound program or sound setting.
Jun 13, 2009 | Audio Players & Recorders
Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Jun 01, 2009 | Dynex DX-LCD32-09 LCD TV
Problems hooking up dvd player to Dynex 22"
MY PROBLEM IS THAT WHEN I HOOKED UP MY DVD PLAYER (PANASONIC) THE MOVIES COME OUT IN BLACK AND WHITE. WHY IS THAT. PLEASE ADVISE
Mar 09, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Samsung DVD-VR320 DVD Recorder/VCR Logo
1,527 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
