Have a new nordyne heat pump installed and em heat will not come on.
  • 22 Answers
The EM heat is your electric heat element, it probably need to be wired in at the thermostat or air handler, you need a volt/ ohm meter to be sure and a basic knowledge of eletricity, if you don't do not touch it, let a service tech. do it for you, better safe than sorry.
Posted on Feb 01, 2010
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Heat pump squeal
It sounds like a bearing going in the motor. Most likely the front and probably not oil-able. If it is, 10 drops, non detergent, 10 weight. No penetrating oil. Work the shaft in and out as well as back and forth on-till loose. Be sure to kill all power first!!!!!!
Dec 09, 2013 | AO Smith Miller / LSI / Home / Nordyne...
Is there a system mismatch with an American Standard 13 seer 3 ton compressor and a Nordyne 3.5 ton air handler? Noise at TRV when heating.
This must be a heat pump? Sometimes the unit can be more efficient with this combonation. What you are probably hearing is the reverse direction of the
refrigerant going back through the liquid line.
If in cooling sometimes you can hear a gurgling sound going through the expansion valve, sometimes
this is a sign of low refrigerant or the system is fine..
If you recently had the outdoor unit replaced and noise is an issue, check to see if the unit has isolation pads installed underneath the unit whether
it be on concrete slab or on brackets mounted to
house. Sometimes the new units come with compressor that has a jacket installed over it
Feb 14, 2010 | Ruud Central System Air Conditioner
Heat pump runs in em heat when outside temperature is low
Yes, you may turn to em heat only. May this confirmation help you.
Jan 06, 2010 | Heating & Cooling
Nordyne GB5BM T49K C what heat strips do I need or what KW ?
You need to know how much heat you need (heat loss) and then figure the KW of heat that you need to make that. (3415 BTU's per KW)
Nov 10, 2009 | Heating & Cooling
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Oct 16, 2009 | Ruud Central System Air Conditioner
I have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Mar 17, 2009 | Heating & Cooling
Nordyne electric furnace heats up but fan won't come on when set to auto. Is it a relay switch. Have installed a new thermostat.
If the fan runs in the ON setting then you have a bad fan relay for the heat mode.
Did you install the t-stat before or after the problem?
If after, you have a bad fan relay.
Feb 21, 2009 | Heating & Cooling
Electric heat strip installation and wiring
Need to make sure your wire size to the inside unit is large enough to handle the amperage, that you have a two stage heat thermostat.
Jan 02, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
174 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
