Question about Abit VT7 (MBABITVT7) Motherboard
I need to get the Motherboard User Manual for the ABIT-Vt7. I need to attach the connectors that go from the front panel of the Computer Case to the connectors on the Motherboard
  • 728 Answers
You can find that manual HERE.
Good Luck,
Mark
Posted on Jan 31, 2010
HOW TO CLEAR CMOS ON ABIT VT7
on your board it will say cmos pin 1 and 2 are closed make sure that your computer is off then put the jumper on 2 and 3 turn it on then turn off computer then put the jumper back to pin 1 and2 then startup compter
Mar 24, 2013 | Abit VT7 Motherboard
Reconnecting the pwr switch and HDD Led wires,etc
Hello here are the manual in pdf:
http://pclap.hu/driver_files/nf7_series.pdf
You will need adobe reader, to read content.
The front panel connector, look likes this:
Here are the abit homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Good luck
Sep 24, 2012 | Abit nForce2 NF7-S2 Motherboard
ABIT-BD711
Okay,.......that was DU-MB!
Lemme see,.......oh yeah!
Letters and words! !O_O!
(Wondered where my glasses were!)
http://images.search.yahoo.com/images/view;_ylt=A2KJkCAV3j9QW2cAUAOJzbkF;_ylu=X3oDMTBlMTQ4cGxyBHNlYwNzcgRzbGsDaW1n?back=http%3A%2F%2Fimages.search.yahoo.com%2Fsearch%2Fimages%3Fp%3Dabit%2Bbd711%26fr%3Dmoz35%26fr2%3Dpiv-web%26tab%3Dorganic%26ri%3D2&w=600&h=444&imgurl=www.ixbt.com%2Fmainboard%2Fimages%2Froundup-i845e%2Fbd7ii-raid-board.jpg&rurl=http%3A%2F%2Fixbtlabs.com%2Farticles2%2Froundupmobo%2Fabit-bd7ii-raid-i845e.html&size=111.5+KB&name=Abit+BD7II-RAID+%28i845E%29+Mainboard&p=abit+bd711&oid=14ba8ece461cfe2b401fe4f974d4c0b7&fr2=piv-web&fr=moz35&tt=Abit%2BBD7II-RAID%2B%2528i845E%2529%2BMainboard&b=0&ni=56&no=2&ts=&tab=organic&sigr=124cn6s7j&sigb=12vbgaaru&sigi=120054ob4&.crumb=J6iwC7bwOtM
Motherboard photo, and detailed info below it. Scroll down.
Looking at the motherboard installed in the computer case:
1) To the right of the Ram Memory slots, and in the upper right corner, is the 20-pin ATX main power cable connector, on the motherboard.
Whitish connector with two columns of 10 socket holes.
A 20-pin ATX main power cable plugs in here,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note the Lock on the side of the power cable's connector, (Middle photo, and right photo), and the Tab on the motherboard connector, (Left photo)
When the power cable is plugged in correctly, the hooked end of the Lock on the power cable's connector, will be hooked over the Tab on the motherboard connector.
2) Look at the bottom Left corner of the Processor socket. Note the three cylindrical objects. (Radial Aluminum Electrolytic Capacitors)
Note the whitish square 4-socket hole connector below them.
This is where the 4-pin ATX +12 Volt power cable goes. It also has a Lock, just like the 20-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for your Intel Pentium 4 processor.
3) To the Right of the Ram Memory slots, and located below the whitish 20-pin ATX main power cable connector, are the two IDE connectors. (Turquoise Blue)
One is for an IDE (PATA) harddrive, and one is for an IDE(PATA) optical drive. (CD/DVD drive)
The one on the outside near the edge of the motherboard, has IDE1 next to it.
It is for the Harddrive.
The one closer to the middle of the motherboard is IDE2.
It is for the optical drive. (Or drives { 2 } )
NOTE*
One side of those rectangular connectors has a cutout in the middle.
(Square U-shape cutout)
This is where the Locating Lug, on the flat ribbon IDE cable's connector, goes to.
It aligns Number 1 pin in the connector, with Number 1 wire, in the flat ribbon IDE cable.
IF, there is NO Locating Lug on the flat ribbon IDE cable;
On one side of the flat ribbon IDE cable is a thin RED stripe.
This stripe denotes the side that Number 1 wire is on,
http://en.wikipedia.org/wiki/File:Nappe.svg
Looking at the rectangular IDE1 and IDE2 connectors, Number 1 pin is at the BOTTOM of those connectors.
(Motherboard installed in computer case)
On an IDE harddrive, Number 1 pin is ALWAYS towards the 4-pin power connector.
Same with an optical drive.
4) Since this is a motherboard, that has a RAID option for using multiple harddrives, I'm guessing the two Yellow rectangular connectors, below the two rectangular Turquoise Blue IDE connectors, is for more IDE harddrives.
http://en.wikipedia.org/wiki/RAID
5) Below the two Yellow IDE harddrive connectors is a Black rectangular connector.
This has 34 pins, and is for a Floppy Drive, IF a Floppy drive is used.
6) Below the Black Floppy Drive connector on the motherboard, is the Front Panel header.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
What is needed here is a Front Panel header pinout.
Dunno. Photo isn't clear enough.
Looks like a Black rectangular strip of plastic, with 8 pins in a row.
4 pins, 3 spaces, 1 pin, 1 space, 3 pins.
Looking closely, (And you may need a bright light, and a magnifying glass), what are the abbreviations next to the pins, on the outside edge of the motherboard?
HDD = HarDDrive activity LED (Light)
PW = Power On switch
RST = Reset switch
PWLED, or close to that effect = Power On LED.
Post back in a Comment.
IF, it is just a row of single pins going across, I would use an LED light that has two wires on it.
Computer, (Power Supply actually), plugged into power, touch the two wires to the first two pins.
Nothing?
Go on.
When the Power Supply comes on you know you have the Power On switch pins (2)
Now go back through, but do not touch those pins again.
LED light blinks? = HarDDrive activity LED (Light)
LED light stays on? = Power On LED (Light)
Computer restarts? = Restart switch pins
7) To the left of the white long PCI slots, (There are 5 towards the bottom of the motherboard), are two small Black rectangular connectors. Each has 4 pins in it.
The one that has Audio, or CD, or CD-IN, is for the audio cable from the CD/DVD drive.
8) At the Top of the motherboard in-between the Processor socket, and black Ram Memory slots, is an Orangish connector with 3 pins. Should have CPU, or CPU_FAN next to it. This is where the Processor fan plugs in.
9) At the bottom/left, and below the two small black connectors with 4 pins in them, is an Orangish connector with 3 pins.
This should be for the computer case fan.
(SYS_FAN)
Additionally you may want to join this website, and ask them for the Front Panel header pinout, for your Abit BD711 motherboard,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
Finding information for an ABIT BD711 motherboard, is about as rare as finding hen's teeth.
I, and I'm sure 100's of people, would be in your debt, if you would post the Front panel header pinout for this motherboard.
Hope I have redeemed myself for the S.N.A.F.U. of the question asked in the Comment, lol!
Regards,
joecoolvette
Aug 30, 2012 | Computers & Internet
Hello i have a windows xp that are installed in an ide drive.but I am attempting to install a SATA samsung hd 250 G in a Abit VT7 A floppy disk came with the vt7 that had the drivers for the SATA...
XP can't be installed in SATA drives because it doesn't have a generic driver for them. Begin the install and during the procedure you will be asked to press F6 to install extra drivers - do just that with the driver that came on a floppy.
Oct 04, 2010 | Abit VT7 Motherboard
Installing a new motherboard and need know where to plug in various cords
all cables are unique so it's quite simple follow instruction in MB manual
Jan 22, 2010 | Abit VT7 Motherboard
Abit an7 motherboard front panel wiring diagram needed :)
Front pannel audio is located left of the pci slots
: : : . : : :   thats what it looks like         from left to right there are seven sets of pins 1234567.
3 and 7 should be the pins you want for a standard front panel audio as far as i see in the manual ICEBOX
Mar 22, 2009 | Abit AN7 Motherboard
Mobo doesn't recognize hdd
Your board shows serial ATA compatibility, I'm pretty sure the Seagate 1.5TB HDD is a serial ATA II device. These are not backwards compatible. Sorry. Hope this helps.
Dec 23, 2008 | Abit VT7 (MBABITVT7) Motherboard
Abit NF-M2S Power Led Connector
The model number for your Abit motherboard is incorrect (Abit doesn't list one with it). I think I might have found what you really have, though. If so, the power LED attaches to the opposite side of the speaker connector, which is next to another set of headers. You should see it notated as such on the MB, too.
Feel free to take a look at it, and see if it matches what you have:
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&category=5&subcategory=247&model=124&product_name=NF7-S+v2.0
Cheers
Nov 12, 2008 | Abit NF-M2S Motherboard
Abit motherboard nf-m2s
Hi chatzmoe, on page 8 of you're manual is a picture & layout for you're abit NF-M2S front panel connectors for LED's.
If you're current manual does not show this, tham download the manual from the link below.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF-M2S&fMTYPE=Socket%20AM2&pPRODINFO=Manual
Main web page for Abit NF-M2S.
Have more questions? Please feel free to ask.
Luck!
Mike
May 08, 2008 | Abit NF-M2S Motherboard
Abit VT7 (MBABITVT7) Motherboard Logo
214 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
