Question about Refrigerators
ICE MAKER AND WATER SUPPLY DOES NOT WORK
The ice maker and water is not working. There is a clack noise as if a switch was tripping.
  • 1 more comment
  • lew223 Feb 18, 2008
    I have the same problem, but the water dispenser does work. I notice the ice maker is making a clicking noise, and the amount of ice in storage bin is getting lower. It still makes this clicking noise, even if the icemaker shut-off arm is raised. The filter is 2 months old. I have the Maytag model MSD2454GRW
  • har12342 Jul 05, 2008
    my whirlpool top freezer refrigerator is making a clicking sound. I have put lever up = off position for hours. Still clicking. I put lever down = on position. Still clicking. Turned fridge off. Still clicking. Unplugged electricity = no clicking. Checked waterline, checked for stucked ice cube - checks ok.
    Clicking sound and no ice - what else can I do
  • robert samples May 11, 2010
    WHAT MODEL AND BRAND IS IT HAVE YOU CHANGED THE FILTER AND HOW OLD IS IT
I lifted the switch to turn ice maker off, left it like that for a couple of hours, then turned it back on. I checked it a couple of hours later....Making ice now....
Thanks pete5runner!!!
Posted on Feb 19, 2008
  • 55 Answers
Try emptying the ice bin. The ice cubes may have frozen together. Anbd the water line may have frozen. Try turning the unit off for awhile to defost water line.
My Amana side by side refrigerator stop dispensing waer. No noise at all,
Posted on May 19, 2009
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: ICE MAKER AND WATER SUPPLY DOES NOT WORK
it's the relay snapping..maybe it's hot, or bothered, and needs to be replaced. it's usually at the bottom of the unit, and not hard to get too..
kenmore parts are at www.sears.com
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Feb 19, 2008 | Refrigerators
My Hoover Frost Free A class HTK 95AA has a trickling water noise coming from the back around the cooling pipes when switched on. The compressor gets very hot although the cooling pipes do not, is it
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Kenmore WR30X0318 Ice Maker Stopped Making Ice
The ice maker uses a internal thermostat that starts the cycle of dropping the ice and refilling with tap water. If your water control valve works filling the ice maker then the problem is the ice maker itself that will need replaced. Unfortuantly the ice maker you have has no rebuildable parts and will need to be replace with a=> WR30X10093 Ice Maker Assembly
Or here=> WR30X10093 Ice Maker Let me know if you have questions, Thanks Sea Breeze
Nov 14, 2012 | Kenmore Refrigerators
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
Feb 06, 2012 | LG LSC26905TT Side by Side Refrigerator
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Steam function SAECO Vienna Exclusive not works
Check the thermostat on the steam boiler, that could have tripped, or the element on there could be damaged.
Jan 23, 2010 | Saeco Vienna De Luxe Espresso Machine
Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker tray does not fill with water
replace the duel inlet water valve on the bottom back of frig.,one side has failed-mike
May 22, 2009 | Kenmore Refrigerators
Refrigerators Logo
588 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
