Question about Stanley Air Tools & Compressors
Spark from the front motor smells like burning plastic used 3 times
    Scholar:
  • 169 Answers
Dead give away that the motor is done, there is a very specific smell when the windings burn, would have to say you got a bad one.
Posted on Feb 01, 2010
#1 CYLINDER WONT FIRE
no year, ?
try a new spark plug e and then if wires to spark plug , replace that too. and cap and rotor if it has that....?????
then when spark is good, check compression with any $20 gauge.
no year, i give up.
1976 accord? surely ive no clue.
smoke has 3 colors, (my rules not ASE)
1 black fuel (flooding etc) can seem gray but is black .
2: white and lingers., oil burning , bad. news.
3: white and fades fast, is STEAM, like moms tea pot, look next time..
smell white smoke, smells sweet, its toxic antifreeze.
smells like oil dripped on an hot exhaust? that is the smell of oil burning
smoke where, under front of car, or at the end of the tail pipe. ?????????????
how you like my smoke rules, even mom can figure it out.
Dec 13, 2013 | Honda Accord Cars & Trucks
Motor issues
A faint burnt plastic smell is actually normal for these when brand new, but that normally disappears after a week or so. As for sparks, a thin trail of blue sparks trailing along the commutator (the uppermost part of the motor that can be seen rotating) is normal. However, if there are blue, orange sparks flying out of it its toast. The motor is dying in that machine.
Nov 23, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Burning plastic smell from under hood
You will need to check where the liquid is coming from, It may be anything from Air Con, Fuel, Transmission Fluid etc..
The fact you smell burning plastic could be 3 things..
1, Brake pads could smell and burn down if they are on too tight (Had this problem with a trailer). Hence when you apply the brakes it could be squirting brake fluid out due to too much pressure.
- Check brake fluid
2, If the smell and liquid is inside the car (front pass side) it could be the air ducts. Under the dashboard you have air ducts etc for the fans and in car cooling (brother had issue with this)
3, Whatever the fluid is, it could possibly drip onto something hot, unusual for liquid to smell like plastic though, Auto transmission oil smells like fish.
Best bet would be the brakes. Next time you smell it just smell in the wheel mag and see if you can smell it, check the engine fluids often and dont use A/C (Air Con) as that does drip fluid (normal). If it is the brakes smelling you will need to have the lines bled out, tyre places may be able to do this, and possibly new brake pads
Good luck
Oct 20, 2012 | 2007 Suzuki XL-7
I have purchased a kenwood FP270 food
not sure if this helps, but we bought the same FP270 11 months ago & use it 3-4 times a week with juicing attachment with carrots & apples. Last week the motor started to smell, and motor burnt out completely today with dust & noxious smoke coming out of the bottom. The Good Guys exchanged it for FPM270 with no hassles under warranty. I don't think the motor is powerful enough for serious kitchen work & had many cracks in the plastic parts.
Feb 17, 2011 | Kenwood Food Processors
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Screen distorted and burning smell
Those dead resistors that the cause,u are smelling burning plastics.Try website Tvrepairworld.com to buy a whole convergence board for the replacement.The Samsung/Akai are using the same convergence board.
Jun 06, 2010 | Akai PT4250A 42" HDTV
Smells like the motor is burning. observing sparks. It the motor cooked and is it just time for a replacement?
If you're observing sparks, then yes, just get a new one. With the low prices of good vaccuums its not worth starting a fire with your vaccuum. If it just smells like the motor is burning, check the belt and make sure its rotating freely and if you have an attachment, make sure the brush on the vaccuum is not being stopped while using the attachment. However, if you are seeing sparks,,,, definately time to junk it
Aug 20, 2009 | Sharp Twin Energy EC-TU2603 Bagged Upright...
Sparks and burning plastic
Leave the back off and try to power the set on...be ready to pull the plug. Whatever is sparking/smoking is your bad part. On this TV I would suspect the flyback transformer or grey rectangular polyester capacitor mounted in front of a heatsink on the left.
Jul 06, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
The dryer makes a loud noise and also a rubber smell develops after a 1/2 hour of use
My dryer did the same thing. I had to replace the front support glide assembly and needed 4 teflon glides.
The front part of the dryer runs over this plastic piece seen here upside down.
this part is about $50 CAN there are 4 plastic or teflon glides that fit into this.
My dryer had worn through the teflon glides and start wearing away this piece.
My dryer is a GE front load dryer. And I did get a burning smell because the dryer was wearing away the plastic. After the teflon strips wore down.
Hope this helps
Jun 01, 2009 | Kenmore Dryers
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Air Tools & Compressors Logo
215 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
