Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
How can I access the roller belt in Kenmore Powermate 116 53313305? with no screws. Does the entire black half separate from the blue half?
If there are no screws on the underside (like mine) you need to remove the top light cover. There are tabs on either side that need to be pressed in so it pops out. Under the light cover there are two screws located in the center. Remove those and the blue and black components should come right off.
Posted on Feb 21, 2010
  • 701 Answers
If you turn the power brush over there are (2) screws on the bottom close to the back wheels on each side. Remove the screws and you will be able to separate the top cover from the base and get to the belt. You can get a replacement belt here:
Kenmore Progressive Belt
Posted on Jan 31, 2010
Cant open roller assembly roller not spinning i dont see anything in the way
Turn the power head over so the bottom is facing up. On the bottom towards the back there are two holes (one on each side) where you can get to the access screws. Remove the two screws (you'll need a phillips screwdriver). With the screws removed you can now remove the top cover from the base by pulling out on the two clips on each side of the power head. With the top cover removed you can get to the belt and roller brush. If you need a belt for this model you can get it here:
http://www.vacbelts.com/20-5218-belt.htm
Don't forget to rate the answer!
Jan 07, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
How I replace the belt for Kenmore 116 3063500C ser M53101631
Turn it over and on the bottom are (2) screws. Remove those and the top cover will come off and you can access the belt.
Jan 08, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
How do you open up the power head to check the belt?
Oct 22, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
The roller stop turning, power is on.
After you have removed the screws you need to remove the rubber bumper that encircles the vacuum head.
Aug 23, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Need to check belt on a Kenmore WhisperTone powermate vacuum
There are two screws. Pry off the light bar on top by pushing against the sides, and you will see them inside just behind the light bulb.
Apr 04, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
The belt in the PowerMate won't run
If the motor on the floor attachment runs, it could just be a worn belt - it can be replaced. Also check the switch to turn the attachment on, and the electrical connections in the hose and wand from the vacum all the way to the attachment. An electrical meter could be used to check for power at the motor in the attachment also - just be careful. Here's the instruction book, in case it's of use.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0412323.pdf
Please rate if this helps :)
Feb 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Roller bar does not spin
It has a restart button that fixed the problem - I took it to a repair shop and they solved it.
Apr 18, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore Powermate Canister Vacuum Cleaner
Depending on which model, there is a couple of scres on the bottom, then on each side and back are release catchs that you pry up to release the top, then you can get to the belt. The other model you take off the light cover, it just snaps in place, then you can take out 2 screws from the top, on each side there is a slot, put a screwdriver up into the slot and pry out to release the tabs, then the cover comes off and you can get to the belt.
Feb 10, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Roller brush of vacuum not rotating
u might need 2 change the belt on the attachement there r 2 screws on top take em out after u take off cover there is a plastic cover over the belt take off c if the belt broke the rest is easy
Apr 15, 2007 | Kenmore Magic Blue 24195 Bagged Canister...
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
489 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
