Question about Mitsubishi Televison & Video
What causes small light spots on the TV screen that began with one and now there are 11.
    Guru:
  • 114 Answers
DLP?
if the spots are like these What causes small light spots on the TV screen - dbe4950.jpg
its the DMD board....
try this website...
http://www.discount-merchant.com/SearchResults.asp?Search=DMD
Posted on Feb 05, 2010
  • 135 Answers
If it is a DLP the DLP chip is going bad
Posted on Feb 01, 2010
Cause of dark spot on 1/4 of & vertical streaked shadows on the rest of screen?
Sounds like panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2015 | Televison & Video
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
My tv has small white dots of lights in most of the screen can this be fixed.
Ensure your input device is not causing this, by changing the TV input to a different video device. Then, look for any loose contacts on the RC cable or input cable. If nothing works, better refer it to a qualified service technician.
Jul 19, 2012 | Philips 42MF531D 42 in. LCD Television
I have pink spots on my tv screen. do you know
you most likely have a light engine problem ocouring causing the pink spots
they usualy have to be replaced with a remanufactured light engine you might see if you got a extended warranty on the unit as this can be a tad expensive
Oct 30, 2009 | Panasonic PT-44LCX65 Television
Zenith model D52wlcd projection TV has been saying replace lamp for several weeks. Has had a small pink spot in middle of screen. Now full screen is pink. is this a lamp problem or just DOA?
The Lamp will no cause any color distortion. The "Replace Lamp" message comes up after a certain amount of hours after watching the TV because the lamp only last a certain number of hours before needing a replacement one.
It sounds like a light engine problem. There is no quick fix, you need to replace the whole light engine which is very costly (light engines usually run at least $500) and time consuming (need to take whole TV apart to replace part).
Oct 07, 2009 | Zenith D52WLCD 52" Rear Projection...
HOW TO CLEAN SCREEN WHAT CLEANING PRODUCT TO USE
The screen you are referring to is the outside screen of the tv correct?
Test your technique in small area first. It is important that you understand there is a risk with this process. It is very important that no liquid runs into the sides of the screen. This will wick into the screen and cause damage or water spots. Just a lightly dampend very soft cloth is all that is needed.
Jul 03, 2009 | Hitachi Televison & Video
No power on LC32D50U Sharp
This is glennac. I figured out what happened and thought I would update for others. The display had stopped working soon after mounting it to a wall mount. I discovered, when I began removing it to take it to the shop, that it started working again once I had loosened one of the mounts screws. Tightening it back in caused the display to lose power again. What I discovered was that there is a spot on the back against which the mount plate rests which, if pressed too hard, cuts the power. Backing the screw out relieved the pressure on this spot and now the TV works again. Facing the back of the display, the spot is at about the 11:00 o'clock position from the center, halfway between the center and the top.
Feb 07, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
Aug 15, 2008 | RCA LCDX2722W 27 in. Television
PT 44 LCX 65 Panasonic Red spot upper rt quadrant of screen
This is a FIRMWARE problem. do not let someone replace any parts in your TV.
I had a repair guy come out with a small computer and he took the back off of my tv, plugged in the computer and the red dot slowly began to disappear.
this was in March 08, no problems since
Dec 18, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Open Questions:
Televison & Video Logo
816 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
