Question about Verbatim 500GB USB Desktop 500 GB Hard Drive
Attached my SureFire SX500 portable hard drive (by
Attached my newSureFire SX500 portable hard drive (by USB cable). In computer management it shows the device but with no drive letter. Right click on the SureFirt it and the drop down list appears, but all options are light shadow - click on format and nothing happens.
    Guru:
  • 194 Answers
Sounds like you might have to initialize the hard drive. Go to the left on that hard drive (where it says Disk 1 or 2, etc) and right click. It should give you the option to initialize. From here you should be able to format, etc.
Good Luck,
NOLA Tech
Posted on Jan 31, 2010
Toshiba 500gb hard drive is not visible on my computer, the hard drive has a light but it is not showing on my computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps
Sep 03, 2012 | Computers & Internet
When I attached the external HD via USB it doesn't show up on my computer.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of :unforeseen problems:
hope this helps
Jul 07, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
When i connect my portable hard disk to my pc...its simply not getting detected....
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. If you received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 07, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My WD250gb wont show up ? it is not working ?
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the USB. If you received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 06, 2011 | Western Digital WD Passport 250GB Portable...
Hi, my Immation Portable 160GB as soon as I plug it into my computer, the light is on, the HD seems to be working, but on my pc it doesnt even appear on MY COMPUTER the disk to open. I plug it and windows...
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Jun 17, 2011 | Imation Apollo Portable - Hard drive - 160...
I connect the USB 3.0 portable hard drive for Iomega its not working in my computer but i connect another computer its working tell me solution
May 23, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm SimpleTech SimpleDrive Portable USB 2.0 60GB wont show up
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Apr 22, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
I am trying to download movies off my friends portable hard drive onto my laptop but when I plug in my friends hard drive into my laptop, my laptop don't recognize it and nothing comes up???
Your laptop's usb port may not have enough power to keep the portable hard drive running.
You may require additional power to the portable hdd by using a usb cable with 2 usb connectors.
or use a USB port that is powered.
Mar 03, 2011 | Computers & Internet
I attached the portable drive to my computer and i don't know what else to do
If a Windows based machine, locate and double click "My Computer" (or similar). A box will open and show the devices attached to your computer. Fixed drives such as "C:" appear under "hard disks and CD, DVD players, external drives and thumb drives will appear as "devices with removable storage" or as "portable storage"
Plug the drive's USB cable into the computer (if it isn't already) and double click the new drive to view the contents. Often times, these drives ship with software to perform back ups, or other utility - or include the manual and warranty information. You can use the drive as if it were one of the other permanently connected drives inside your computer.
Make sure that you click on the "Safely Remove Hardware" icon in the System Tray BEFORE unplugging the drive's USB cable. Data loss can result if disconnected before the data has been written completely to the disk.
I hope this helped & good luck!
Nov 01, 2010 | Seagate Computers & Internet
Verbatim 500GB USB Desktop 500 GB Hard Drive Logo
78 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
