No water going in to the machine - Washing Machines
  • 12,061 Answers
Check the obvious, there is water pressure? ...It sounds as though the water IN solenoid has failed. or the sensor or the microprocessor brain. Generally due to this it must be looked at by a qualified service person. get a firm "Quote" for the work before proceeding.
Posted on Feb 01, 2010
Does anyone know Why the hot water does not go into the machine when using warm water selection, hot water is in hose but not in machine ?
The hot water valve is not opening. This could be the valve or the timer. What make and model and year is it?
Sep 12, 2014 | Washing Machines
Water wont go into the machine but the wash light comes on here a clink but dosent fill with water an start cycle help plz
IF YOU ARE SURE THE WATER SUPPLY IS ON. SHUT OFF WATER TO MACHINE AND REMOVE HOSES ON BACK OF MACHINE AND CK SCREEN ON VALVE THEY CAN BECOME PLUGED AND WILL BLOCK WATER FLOW. PUT THE HOSES IN A BUCKET AND TURN ON JUST TO BE SURE IT IS NOT ANOTHER PLUMBING PROBLEM.
Apr 21, 2014 | Indesit WA 115 Front Load Washer
Error message stating waterline connection - water all of a sudden not getting to machine.
well if u have water going to the back of the machine then id say the water solenoid is like to have failed
r u sure that the water is turned or isnt stopped up or something going to the machine
Jan 24, 2011 | LG WM2688HWM TROMM SteamWasher
After wash, water is not going out.....
First you tell whether it is a front load machine or top load machine in both the machine after the wash cycle it will send the water out then it will take water once more to do the rinse then finally it will do spin
May 18, 2010 | Washing Machines
Solis palazzo espresso maker / water tank problem
HI
Did you push the water button, before you opened the knob? When you finished descaling did the lights change? On any compact machine you need the let the pump stop on its own. Then go to the next part, rinsing. Again letting the machine stop on its own. Pump will stop and the lights will change. Once the machine has finished rinsing. You will have a steady water light and a blinking green light. Put your tank back on with fresh water, then push the water button(far right), then open the knob for water. The red light should go out, and the machine will heat again.
Dec 22, 2009 | Coffee Makers & Espresso Machines
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Hot water not going into washing machine
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Nov 05, 2008 | Frigidaire Gallery GLWS1339EC Top Load...
Ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Jul 01, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
