I have a behringer djx 750 mixer which has a booth output at tha rear. Can I run a self powered speaker as a monitor straight from this line out and control volume etc from the mixer.
    Champion:
  • 211 Answers
Yes you can drive self-powered speakers on both outputs (master and booth).
You can control the boothoutput with the monitor level.
Use your cue buttons to activate the booth-output.
Regards,
Gerard
Posted on Jan 31, 2010
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
Djx 750 - no power - transformer dead?
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
Feb 16, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer djx 750 headphone
What is the problem. A description might help get your questions resolved.
Jan 22, 2013 | Behringer DJX750 5-Channel DJ Mixer
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
How to connect floor monitor to mixer
You need to connect the speakers using an XLR cable into the Main output jack on the back of the mixer. If they are powered speakers you will need to connect them into a power source and turn them on AFTER connecting them. Once powered on you can control the signal going to the mixer with the Main Mix fader.
  1. Turn mixer on
  2. Ensure Main Mix level is at zero
  3. Connect from Main Output to Monitors
  4. Turn Monitors on
  5. Turn up Main mix to desired level
Sep 14, 2011 | Behringer XENYX 2442FX Mixer
Will a Behringer UB2442fx-PRO run 2 main PA speakers plus two passive stage monitors without blowing up?
ALL the speakers will either have to be POWERED or have external amplifiers. The mixer has NO power amps capable of driving speakers. When connecting, make sure that the mixer is powered by the same receptacle as the speakers or amps. Used balanced line for interconnection.
Jan 24, 2011 | Behringer Music
Can i connect 2 amps on djm 3000? If yes how?
I currently have 3 amps connected to one mixer. All you need is to check where your amp is currently plugged into the mixer. now get yourself 2x RCA two way splitters at your local music shop (ie. One male to 2 female)split the channels from your mixer input, and an extra amp can be plugged into the spare plugs
Apr 14, 2010 | Pioneer Djm-909 DJ Performance Mixer with...
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
237 people viewed this question
 Grubhead
Grubhead
