Question about Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Settings or Broke
Ekkk Nikon D50
Thinking I would finally go from auto and learn manual I played with settings at Christmas and got the sucker all screwed up. Now I can't even get my zoom to work. Have i killed it? I hit the reset config many times. My 18-55 works but when I attach my 70-300 (many times now) it shows F-- flashing on auto and wont allow me to shoot a shot. When i put 70-300 on manual it will shoot on this mode but it shoots black (blank) shots. The F-- is showing still on this mode as well. Here's what the manual said http://www.nikonusa.com/pdf/manuals/dslr/D50_en.pdf
how can i figure out whats wrong? Is the len broke or is it still a setting I have screwed with.
Thanks for any assistance
  • 78 Answers
You need to put the aperture ring - that's the thing that's closest to the camera on the lens - to the highest number possible. On the 70-300 Nikkor, That number is 32.
This will solve your problem! :)
Posted on Apr 08, 2008
I cannot access the advanced settings
Change the setting on your Program dial, try Manual and you should be able to access it. Under certain settings, it will not let you access the advance settings, because you are in a Program mode, like Landscape, Speed, Night, or even Program and Auto.
Mar 21, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
The flashgun doesn't pop up when it should. It remains jammed.
Ok
Its not clear how you are using the camera.
Check the settings on the left. Some settings (Landscape for example will not allow the use of flash)
Set the camera to P,S,A OR M and it will. In Auto it will pop up if it needs it. It It still won't work Look at the menu settings for Flash Mode two settings 1) TTL and the other Manual. I have my D50 set to TTL using the built in flash and manual when using an external flash mounted in the shoe.
Hope this helps
Dec 12, 2009 | Nikon D50 Digital Camera
Nikon D50 will not auto focus.
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Aug 27, 2009 | Nikon D50 Digital Camera
Nikon N75
hi there go and reset to factory settings through menu. You may of locked it. Try using it set to P It sounds like y`ou have locked the focus, Also have you got a button that says manual focus, and auto focus on the front of the camera. see thats not on manual. Best Regards Alex ( Hairydog )
Aug 10, 2009 | Nikon D50 Digital Camera
Can't reset nikon D50 default settings
Press MENU and select the pencil icon to get to the Custom Settings Menu.
First select the "Detailed" mode under Menu > Setup (wrench) Menu > CSM menu, otherwise you'll only to get the first few items!
[R] Menu Reset: This returns everything below to factory default.
Dec 24, 2008 | Nikon D50 Digital Camera
Shutter problem
30 seconds is the maximum setting for the D50. Anything greater than this you can easily time with a watch using the 'bulb' setting.  Most SLR's are like this.
Oct 29, 2008 | Nikon D50 Digital Camera
I can't focus with my nikon D50
Perhaps you have accidentally set the auto-manual focus to manual on the camera body?
Per.
PS. The r10 message is just a report of the current memory buffer status, not an error indication.
Aug 03, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikkon d50 wont auto focus
the D50 will only auto focus with an AF-S lens...make sure you are using an AF-S lens.
Also, check the swithc on the lens is set to "A" not "M" ...
Also, in the menu, check you set the camera as autofocus, not manual focus
Jun 07, 2008 | Nikon Cameras
Auto bracketing on a nikon d50
no. if you want more than 3, you will have to manually bracket those beyond the initial three. alternately, you can get a reading for settings then change to manual and continually adjust your aperture setting from whatever under exposure level you want to whatever over exposure level you want.
mark
Dec 09, 2007 | Nikon D50 Digital Camera
AF area mode problem
To answer your flash question...the Nikon flash system fires the flash when the camera thinks the picture will be too contrasty without the flash. You can Google for "fill flash" to learn more. This is usually beneficial; if not, holding the flash button and turning the main dial will cycle through flash options on the top screen.
Jul 17, 2007 | Nikon D50 Digital Camera
Nikon AF 70-300mm f/4-5.6 G Nikkor Lens Logo
99 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
