Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 5701 2way remote works, but gives buzz for all functions
My viper 5701 2way remote functions and works great, but always responds with a red light, blinking orange light, and a buzzing sound no matter what function it performs. How can I get this to respond the way its supposed to?
Hi did you get this unit from ebay? i am going through the same experience right now and there is a problem with the early units that were manufactured. It will need to be replaced. I am currently trying to get a refund.
Posted on Feb 08, 2010
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
Feb 03, 2014 | Directed Electronics 479V Remote Gen 2...
My viper 5701 alarm is having issues.
First thing is to trip the system to see if the siren works then. If it does, then perhaps you inadvertently set the chirp commands to silent. If the siren doesn't work when the system is tripped then that's your problem. You'll need to find the siren and troubleshoot possible causes. I'd start with the wiring but the siren could have simply gone bad. You should be able to test it easily with a test light or multi-meter.
Mar 19, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
2-Way Remote not responding as it should
Change the battery. The 2 way remote batterys drain after about 3 months.
Mar 16, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote keypad
You probably need to change the battery in the remote. AutoZone has a thing on the counter that will check the battery for you.
Feb 06, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
1,036 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
