Wiring a NAD power amp to a NAD receiver
I need a diagram on how to wire these 2 devices along with a CD player. ITs been soo long ive forgotten how
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi, what models do you have... pre and power amp particularly
    regards
    Graeme
  • 1,512 Answers
Hi again, If you can tell me the mpodels, I can get the manuals for you, and also give you advice on the best way top connect them. Some NAD power/pre amps have more than 1 set of in outs. The models will help to advise you.
regards
Graeme
Posted on Feb 22, 2008
I am installing the CD Reciever in a Vintage Airstream Travel Trailer. The power wire, ground wire and speaker wires, should be no problem. (Neg ground) do I need the Mute, Illumination and remote? I...
1)The mute cable is to mute your CD Receiver when you get a call on your mobile phone. You will have to buy a car mobile dock for your phone and it will have a mute wire on it, which you will have to connect to your CD Receivers mute wire.
2) The illumination wire is to be connected to the headlight switch of your car. In some CD Receivers it will turn on the display at night along with the headlight. On some models it dims the back light at night along with headlight so that the bright light which is needed during the day does not distract your driving at night.
3) Remote wire is for triggering another device along with the CD Receiver,like an additional power amplifier or a Sub woofer etc.
Mar 21, 2011 | Car Audio & Video
Is there a wiring diagram for the nikkai EAPA450 Amp
Hi, if you still need a photocopy of instructions email me mail@srands.co.uk
If you want instructions in brief this involves POWER CONNECTIONS, PHONO LEAD & SPEAKER CONNECTIONS:
POWER (At the same time when routing these wires, I would connect the PHONO LEADS from the car cd player to the amp, if your car cd player only has 1 preout (1red & 1 white) then you will need two phono splitters, a female to 2 males. Phono leads carry the unamplified sound from cd player to the amp):
~ Permanent 12V+ (Thick lead that is fused direct from battery all the way to the amp, wire must be 20a to 30a +, hence 1cm diameter wire, known as AWG8, Maplin sell cheaper kits then most)
~ Amp REMOTE (A thin insulated cable (5a is OK) from car cd player amp remote wire, this turns the amp on when the cd player is on, if your car doesn't have an amp remote wire, suggest nearest ignition supply or seperate switch that you turn on when you want to turn on the amp)
~ GrouND 12V- (Insulated lead (20a to 30a) to nearest part of unpainted car chassis such as interior panel screw hole, instead of an insulated cable all the way from the batery, this is common practise.
SPEAKER:
Each speaker has a - negative & + positive, these must connected correctly. The amp has 4 channel, 2 channel labeled as front, 2 channels labeled as rear. Using speaker wire, connect cable from amp to speakers. Note: Ensure the speakers being connected only receive sound from the amp (Not cd player as well, as would damage players or at the very least impair sound)
The amp has a feature called bridgeable this means a sub 8" or 10" sub can be powered by 'bridging' two channels. For example there are 2 ways to bridge power a Sub on the NIKKAI EAPA450:
i) Sub speaker wire positive + to channel RL and Sub speaker wire negative - to channel RR.
OR
ii) Sub speaker wire positive + to channel FL and Sub speaker wire negative - to channel FR.
Switches:
~ Bass boost, meant to be on for a channel if using sub, otherwise off.
~ X-over mode adjust hi/lo frequencies, only work if both x-over switches are on! Then adjust switch frequency knob, until it sounds right.
~ Gain (Volume knob) adjust volume knob up or down, until it sounds right!
NOTE:
You will need patience! many hand tools and parts such as: Wiring kit, fuse holder 20a/30a, Phono leads, speaker cable, Fork/ring connectors, wire strippers, wire cutters, set of screw drivers, also ueful to have zip ties to tdy excess cable and 'P' cable clips to tidy speaker wire to shelf, etc.
OK
Any more questions just email me mail@srands.co.uk
Dec 01, 2009 | Car Audio & Video
Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Sep 04, 2009 | Clarion DB148R CD Player
I need the wiring diagram for my new Clarion dxz385usb
Brown wire-Phone mute Yellow 3A-Bus power lead Yellow 15A-Memory backup lead Red-Power lead Blue/White-Amp lead Black-Ground Orange/White-Illumination lead Blue-Auto antennae SPEAKERS(black strip is -ive) gray+gray/black-front right white+white/black-front left purple+purple/black-rear right green+green/black-rear left
Jul 02, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Wiring diagram
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Aug 07, 2008 | Pioneer DEH-P2000 CD Player
Can I connect a power amp to this unit?
If your 2100ES has a selectable INPUT AND OUTPUT and if you're intending to send all signal to the power amp, i.e. not bi-wiring or using the 2100ES to run mid-range or treble then you simply send Left & Right audio (White & Red cable) from a 2100ES output, probably AUX OUT ( it doesn't really matter apart from Phono on some units) straight to the power amp on AUX IN.
We should be just dealing with audio here, so connect the NAD audio output to CD or DVD IN. Select CD or DVD IN on 2100ES input switch and switch output to AUX OUT (whatever you decided goes to the power amp) on the 2100ES. Turn power amp to AUX IN and it will now get an audio signal from the 2100ES for amplification.
Speakers connect to the power amp as a normal amp, so pos and neg etc. The 2100ES now only acts as a signal feed, the power amp does all the work.
So, summary - switch on the NAD, press play - video goes separately and audio goes to the 2100ES. Turn 2100ES to INPUT for NAD. Turn 2100ES to OUTPUT allocated for power amp. Turn INPUT on power amp to allocation for 2100ES.
Turn it up!
Jul 27, 2008 | Sony STR-DA2100ES Receiver
NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
Sep 06, 2007 | Audio Players & Recorders
Help
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Jul 07, 2007 | Aiwa CDC-X217R CD Player
243 people viewed this question
 Grubhead
Grubhead
