Question about Panasonic NN-S933BF Microwave Oven
Our microwave turns on then shuts off after approximatly ten seconds. What can I do to fix this problem?
  • Panasonic Master
  • 12,061 Answers
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, (PSU). Either this or the magnetron is failing. This "Shutdown" happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Posted on Feb 01, 2010
Fan turned on and will not shut off.
Hey friend, thank you for your inquiry!
I see that the fan on your Frigidaire microwave will not shut off. I would suggest performing a reset on it and you can do that by disconnecting the power cord for at least ten minutes. If the reset does not help resolve your issue it could be a potential problem with your fan motor or control panel. We would recommend contacting a professional technician to come out and properly disassemble your microwave to pinpoint which component may need to be replaced. Hopefully this information is helpful to you. -Matt
Jan 17, 2016 | Frigidaire Microwave Ovens
Fridgidaire microwave won't shut off
Good Morning friend, thank you for your post!
I see that you are having difficulties with your Frigidaire microwave not shutting off. This could be a possible issue with your control panel or door switch. I would recommend performing a reset on your microwave and that can help clear out any potential miscommunications. To perform a reset you can flip the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to seek assistance from a professional technician for proper diagnosis and repair. Hope this is helpful. -Matt
Mar 09, 2015 | Frigidaire FMV152KS Stainless Steel 1000...
Microwave will run constantly when door is shut, light is not on but motor is running
Hi Shaniqua, thank you for your question! Let's try resetting the appliance by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the microwave on. If resetting the power does not correct the issue, then once the tech has ruled out a number of possibilities such as a faulty door switch, a potential wiring failure or a communication error with the control board, then he or she can pinpoint the exact problem and the necessary part to fix the issue to determine the root cause to reduce the risk of unnecessary parts.
Aug 17, 2013 | Frigidaire Over-the-Range Microwave
Jennair Microwave Shuts Off after 3 seconds
This is usually a defective or loose bottom door switch or that switch's mount is loose, misaligned or broken.
It's usually caused by opening the door while it's cooking instead of hitting "stop" first) or slamming the door or both.
My help file on door switches is here.
May 19, 2013 | Jenn-Air JMV8186AA Microwave Oven
Panasonic microwave began arcing and now shuts off after a few seconds
Your wave guide cover and magnitron need to be replaced.
Apr 10, 2012 | Panasonic Microwave Ovens
Microwave shuts down after cooking three or four minutes
Your magnetron is overheating and tripping the thermostat, which interrupts power until it cools.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Microwave turns off after 10-15 seconds.
Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
also.
for heating problem
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay
Nov 09, 2008 | Panasonic NN-P794SF Microwave Oven
Open Questions:
Panasonic NN-S933BF Microwave Oven Logo
207 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
