Question about LG LMV2073 1100 Watts Microwave Oven
My LMV2071SS LG Over-the-range Microwave has a burned out bulb. I can't find a replacement anywhere. Can you tell me what type of bulb I should be looking for?
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: LG light bulbs
The part number you need is 6912W1Z004B. You can this part at repairclinic.com for about $4 each. I hope this helps you.
Posted on Dec 22, 2008
vetteman3002
  • 2299 Answers
SOURCE: My LG over the stove
What did LG say? Did they say that they were going to send new covers? A lot of people get confused and think that this site is directly linked to different companies. But we just help people solve do-it-yourself problems. Are you wanting to know where to get new covers? Or are you wanting new light bulbs? I would suggest calling LG again. This should be taken care of by them. The unit is too new to be having this type of problem. But if there is anything I can help you with, I would be more than happy to try to answer any questions that I may be able to answer for you.
Posted on Jan 05, 2011
Interior light burned out
Microwaves have their own type of bulb. Find an appliance parts supply to find one. Perhaps anywhere bulbs are sold if you bring the old one with you. You should be able to access the bulb easily. Some microwaves have an access door on the outside near where the bulb is at. You may require a screwdriver.
Nov 09, 2013 | Emerson Microwave Ovens
Was removing a burned out bulb in my LG LMVM1935SB LG Microwave cooktop/oven. The bulb broke, and we had to finish getting the bulb out of the receptacle. The other light worked, but now apparently is...
When removing a bad bulb ALWAYS unplug the unit. If there is power going to the bulb and when you try to take the bad bulb out and the glass seperates from the bottom base the leads will short out and you will blow your main curcuit board. Then the entire board must be replaced. It will blow out a component on the board or blow a trace off of the back of the board. either way either baord repair or replacement will be needed. ALWAYS UNPLUG THE UNIT WHEN REPLACING A BULB!!!!
Sep 18, 2017 | LG LMVM2075 Microwave Oven
On stove bulbs what is the wattage I need to replace the two bulb's. Everytime I purchase bulbs they don't last long. LG microwave, model # lmvm2055st Thanks, Dave
There should be a sticker in the back that quotes this. 40 Watt is the highest you may go but....buy the 130volt brands as this is a higher rating for 120volt and it will not burn out as quick. Make sure it is an appliance bulb. Most hardware stores like ACE have them. Big Walmarts do too but check the package.
Jan 03, 2011 | LG LMVM2055 Convection/Microwave Oven
LG light bulbs
Dec 22, 2008 | LG LMV1925 Microwave Oven
MICROWAVE LG MODEL MC-806BL LAMP BLOWN
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
In the UK, LG customer support is here. You may find your owner's manual online here.
Dec 19, 2008 | Microwave Ovens
Cleaning ge profile convection microwave
HI HERE THE STEPS TO DISASSEMBLEA gas range cabinet comes apart very easily. Here's how:
Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
PLEASE RATE IT.........................
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need replacement bulbs for over-range hood
These are 20W 120V bulbs with what's called the intermediate base. The new Panasonic part number is ANE6030540AP and you can get them at Tritronics at http://www.wehaveparts.com or Vance Baldwin at http://www.vancebaldwin.com You should also be able to get them at local appliance parts stores, Lowe's (or similar) or even a large grocery store. You can also use Sharp part # RLMPT0003YBE0 from either of the above sites.
Dec 13, 2006 | Panasonic NN-2505A Microwave Oven
LG LMV2073 1100 Watts Microwave Oven Logo
152 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
