Question about Maytag Neptune MAH5500B Front Load Washer
LR signal keeps coming up? - Maytag Neptune MAH5500B Front Load Washer
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question @@@@@@
Posted on Oct 01, 2010
What can cause a 99 Lincoln town car check trac light to come on and stall
Run a diagnostic check on the car. If these codes come up this is what they mean. C1233 No left wheel speed signal
C1234 No right front wheel speed signal
C1236 No LR wheel speed signal
check wiring and sensors
Jul 10, 2016 | 1999 Lincoln Town Car
Lr message
THIS WEBSITE IS VERY USEFUL FOR YOUR MACHINE
http://www.applianceaid.com/neptune8.html
HERE IS THE OUTLINE FOR THE CODE LR
Lr Locked Monitor Rotor Based in signal information from motor control board, the machine control board senses the motor is not turning when requested to run 1.Run motor control board diagnostic test. 2.Check motor control board for damaged components.
3.Check wire connections in harness leading from machine control board to motor control board.
4.Replace responsible component.
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Code LR keeps coming up on my Maytag Neptune TL every time it starts to rinse and I have to stop the washer, wait for it to unlock and start it over again.
can't find lr code open it up inside there is a tech sheet stuck to the side inside the washer put it back when u r done so it will allways be there
Dec 25, 2009 | Washing Machines
Error code Lr
LR usually means that the the signal from the control circuit board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first, if they are ok replace the CCU (central control unit) board, this is the board behind the touch controls.
Nov 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer maytag FAN6800AWW get Lr alarm and dont start, what is thi
HI, this code is signaling an issue that concerns the actual electric motor. a service call is recommended if possible. either the MCU is bad or, the motor has completely failed.
Jun 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Rear door open LR
Not 100% sure on your particular vehicle but there should be a push in style button of some kind that the door presses against when closed. Look for such a thing on the door frame area where door makes contact when closed. If it's faulty, could cause it. It may be as simple as adjusting your door striker in slightly to eliminate or lessen movement of the door.
Apr 15, 2009 | 1996 Land Rover Range Rover
Turn signals, Hazard lights
I would replace the bar switch assembly.
May 18, 2017 | 1998 Jeep Wrangler
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
