Question about Mitsubishi WD-62525 62" Rear Projection HDTV
The t.v. wont turn on. When the problem first started it would turn and then automatically power off. Now it just wont turn on. Can't find the remote and think its on panel lock or something
  • 1,476 Answers
It sounds more like you have a problem in the high voltage circuit. It is the most likely culprit and would certainly cause the problem that you described. You need to get a qualified technician to give you an estimate. If it is a problem in the HV section it should not be more than $200 to repair with parts. Let me know how this works out.
hardrocko
Posted on Jan 31, 2010
50 cc automatic scooter wont start its electrical has power to light horn blinkers but turn key wont start
might pay to check the brushes inside the startermotor, and check connections to it.
Feb 21, 2013 | Motorcycles
When I try to use my automatic start on my viper sst my car wont start up.
The Remote start is hooked up wrong. They have the power for the starter connected to the wrong wire. Its not reading that the car has started and when you put the key in it recognizes that its running. Take in it to who ever installed it and have them change those wires around.
Nov 09, 2011 | 5900 SST 2-Way Security System / Remote...
How do i search for codes on urc20-d1f
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Jan 02, 2011 | Televison & Video
I need the codes for an ASDA remote control, model no: URC20-D1F
URC20 D1F
1. Turn TV on
May 09, 2010 | Universal Remote Control Remote Control
1999 Chevy silverado z71trying to program a new key fob
Use this procedure for New Body Style.
1. Close all doors
2. Insert key into ignition
3. Hold down the power UNLOCK button on the driver's door panel, continue to hold down
until instructed to release in step 9.
4. Perform steps 5 through 8 in a fairly rapid succession.
5. Turn the ignition to the ON position (as far as you can go without starting the engine.)
6. Turn the ignition to the OFF position.
7. Turn the ignition to the ON position (as far as you can go without starting the engine.)
8. Turn the ignition to the OFF position.
9. Release the power UNLOCK button on the door panel. The vehicle should respond by
door locks locking and unlocking automatically. (If locks do not cycle after you let go,
not before you let go of the unlock button, then the vehicle has not entered programming
mode and you must start procedure over. Remove key from ignition, open drivers door
and return to step 1 ). If the locks do cycle automatically then proceed to step 10.
10. Hold down the LOCK and UNLOCK buttons on the remote until the doors lock and
unlock. This may take up to 30 seconds.
11. Repeat step 10 NOW for each additional remote. (Including any existing remotes).
12. Turn the ignition to the ON position to exit the programming mode.
13. Test remote(s).
Apr 29, 2010 | 1999 Chevrolet Silverado 1500
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
1. Turn TV on
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
My remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Sony RMT-D155A Remote Control
I have a philips universal remote i have the codes for it but it wont program can someone help me..
Note:
Sep 24, 2009 | Philips PM3S Remote Control
My remote control will not operate anymore have changed batteries still wont work
Note:
Sep 24, 2009 | Televison & Video
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
