Question about Car Audio & Video
Top Nor trunk won't open or close. message on dash says "trunk not secure". Button won't budge it. Frozen as is. What to do ??
  • 2,926 Answers
Is this a question for a reciever or vehicle???
Posted on Jan 31, 2010
Trunk release button not working
trunk latch or trunk lock cyl. frozen
Oct 04, 2013 | Kia Cars & Trucks
Trunk won,t open so I can get to boot to open mu gas tank
Have you checked the fuse panel for blown fuses? If not, check there first. If so, check to be sure all the wiring harnesses in and around the fuse panel are tight ans secure. If you're really in a pinch and you have rear folding seats you can crawl into the trunk that way.
Jul 24, 2013 | 2003 Audi TT
Ok Joe here is a good one for you. 2007 G6 Pontiac Convertible. I had a problem getting the top to re-deploy from the trunk one day. Took it to the dealer and we were able to get the top to work. While...
Hello! You will need to remove the rear seat...Remove the lower cushion...Remove the hold down bolts...Remove the top of the rear seat..Remove bolts for top of rear seat...Locate the connector that plugs into the trunk latch...With connector in-place, insert the point of a safety pin into the Tan/White wire and tap +12 volts on that pin...Trunk will open..........
Guru..............Saailer
Feb 01, 2011 | Pontiac G6 Cars & Trucks
My pontiac G6 trunk lid is jambed,the dash indicator say 'Trunk Adjar" but we can niether shut it or get it open. both the key fob and the inside relese button seem to be be working in that you can hear...
there is a little finger in the latch that closes when the trunk is closed chances are that the little finger has closed but the trunk is still open... this can be fixed by looking at the latch on the lid you will see a slot with a metal arm in the middle take a screw driver and place it in the hole in the slot at the top. press the button on the fob to open the trunk while your pulling down on the screw driver the little latch should twist letting the screw driver move through the track and pop out now alowing you to close the trunk and being happy again.
Jun 12, 2010 | 2006 Pontiac G6
The trunk when released makes an extended noise that is hard to describe, and it must be slammed several times in order for it to latch. On top of all this when it is latched I get a message that the...
One or both support struts may be defective. Disconnect them both from the trunk lid and lay the ends down into the trunk. You will need to support the trunk lid while doing this and the lid will be quite heavier. Now close the lid to latch. Did it latch first attempt? Check for the dash message. If all appears well, replace both struts.
Aug 15, 2009 | 2007 Mercury Grand Marquis GS Sedan
I have a 2002 chevy cavelier, i used the button on the dash to open the trunk, now the trunk will not latch when i close it.
Try pushing the button under the dash back into its normal 'unactivated' position, and see if the trunk will latch shut. It could be a sticky latch mechanism in the trunk, which some silicone lubricant or WD40 might help to free up. Check also that the latch has not actually returned to the 'locked' position prior to trying to close the trunk. That would definitely stop you from closing the trunk properly! Try unlocking the trunk latching mechanism again.
Jun 08, 2009 | 2000 Chevrolet Cavalier
1996 Saab 900 S Convertable Will not open/close
there are a few reasons that this might be happening but first i would check the compartment where the top is store when down. There are sensors that tell the car if the compartment is ready for use and if the compartment is being obstrcuted you would get that code. email me at Monster50s@yahoo.com if this does not work I may be abloe to help you futher.
Mar 06, 2009 | 1996 Saab 900
1997 BMW 328i convertible
The problem is that your roof(SOFT TOP) lid isnt closing properly. If you open the roof lid you see there is a button on one of the latches that tells the car that the roof is securely closed if your roof lid is not secure the trunk wont open. To test this press down on the roof lid and the try to open the trunk.
Jun 15, 2008 | 1997 BMW 328
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
