Question about Samsung DLP HL-P5663W 56" TV
We have a dark area on the left side of the screen about one inch wide from the top of the screen to the bottom. What could be causing gthis
  • 1,476 Answers
Have you moved the unit recently? If so you may have dislodged the projection unit and have something blocking the left side. Another possiblility would be a bad video card which is not turning on soon enough during the scan. You also may want to check the display format to make sure it is in the proper format for the signal you want to display. Let me know how this works out.
hardrocko
Posted on Jan 31, 2010
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
White block on left side of moniter screen
the screen has failed - i once had a screen with same problems :() order a screen from here newegg.com
Mar 16, 2009 | Computers & Internet
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Lg 37 inch lcd has a dark shadow vertical line down left side of screen about 1cm wide and does not seem to go right to the top or bottom and is slightly wavey
reseat the LVDS cable inside the set. this is the multi wired connector that connects the main board to the panel. if that doesn;t solve your problem replace the main board. if you turn off the set and you can still see it in the screen it is the panel.
Feb 14, 2008 | Televison & Video
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
I have have this TV for almost 3 yrs..now have a shaded area on the left side
The dark side of the screen causes of the lamp alignment or prism glass alignment. This is critical you have to consult your LG technician to do this. But if you have any background o repair consult the service manual. Please careful not to touch the prism quarts so that you maintained the clarity of picture and brightness on the screen.
Aug 27, 2007 | LG RU-52SZ51D 52" Rear Projection...
Dark area on screen
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Feb 07, 2007 | Panasonic CT-34WXD65 34" TV
Samsung DLP HL-P5663W 56" TV Logo
82 people viewed this question
Jerry Greenberg
Jerry Greenberg
