Question about Toshiba Satellite A10 Notebook
I need to replace my hard disk notebook with a bigger capacity hdd
I want to replace my hard disk notebook with much bigger capacity, for now, I had a 30GB.
But, I didn't know what is the biggest maximum hard disk capacity of Toshiba A10-PSA10E bios and motherboard.
i also need some help on how to remove the old drive....
    Problem Solver:
  • 30 Answers
I have read that Hitachi 7200 80Gb harddisk will fit and work in the Toshiba Satellite Pro A10. I am just about to ugrade from a 20Gb drive in my A10. I dont have the model number of the Hitachu drive. What model drive to you now have working in your A10 and what capacity is it?
Posted on Apr 14, 2008
  • 38 Answers
Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
Posted on Feb 18, 2008
Laptop C partition low disk space
Make sure your hard disk has enough space. Most often when the error massage comes it will tell you how much free space is required to install the game look keenly and know how much space is required then either move all media files mainly video files especially downloaded in the download folder to an alternative partition and only leave windows and installed program on Local Disk C. Other wise if your hard disk capacity is very small then am afraid that you will have to get a bigger hard disk.
Nov 27, 2014 | HP Computers & Internet
Swapped out hdd cf-52 nothing happening
When you swapped out the Hard Disk Drive
of the Panasonic Toughbook CF52 it is very
importatnt that you did not "hot" swap the HDD
but that you turned off the unit with a full shutdown
and unplugged it as well.
Once you removed the Hard Disk Drive (HDD)
I am assuming that you replaced the drive with
another drive that had a proper operating system
already installed. If not, then of course nothing
happened since you replaced the HDD with a blank
or unformatted HDD.
One way to verify if the replacement Hard Drive
is recognized by the Toughbook is to go into
the BIOS by pressing the F2 function key and
checking the size or capacity of the replacement
Hard Disk Drive. If it shows the proper value,
then the HDD is recognized at the Hardware Level.
If it shows HDD as None or Zero then the replacement
HDD is NOT recognized and you have to try a different
drive which is functional.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Can i put a usb external hard disk drive on to my netbook and would it make the memory bigger how much bigger can i make it .
It really depends on the capacity of your external hard disk. If it has a larger capacity compared to the one on your notebook, then yes it will make the memory bigger.. Take note, we're talking about memory or storage space and not memory as RAM.
if you want to improve the speed of your notebook then we should talk about RAM Memory. If that's the case, you need more RAM and not hard disk.
Please also remember that notebooks can handle only one hard disk. So, if you want to put your external hard disk into your notebook, you will have to remove the other one.
Regards..
Sep 11, 2011 | ASUS Eee 4G Notebook
I recently installed windows 7 on my dv6565us. Windows still says that the hdd needs to be replaced. My problam is the hdd i need from hp is a 451863-001 and i cannot fid it. does anyone know an...
Any 2.5" SATA hard disk drive (HDD) will work.
Since you are replacing the HDD, you should use this as an oppurtunity to increase capacity.
Newegg.com has an excellent selection of HDD's, fast delivery and awesome customer service.
Remember when you swap out the HDD, to disconnect the power supply and pull the battery before dis assembly.
Jan 06, 2011 | HP Pavilion dv6565us Notebook
How can i increase my hard disk's capacity? my C:\
You need to change the HDD to increase the disk capacity. If you have more free space in D drive and you want to increase the disk size of C drive , then use partition magic software to increase the C drive partition.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Mar 03, 2010 | IBM ThinkPad i Series 1300 Notebook
Hp pavillion9000 notebook hard disk broken
yes, just insure that you have the correct hard drive.... ata or sata.
Jan 26, 2009 | HP Pavilion dv9000z Notebook
About laptop
if you have free slot for ram and and free connector for hdd then you can
Aug 07, 2008 | IBM ThinkPad T23 Notebook
Hard drive
I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
Jul 28, 2008 | Toshiba Satellite A105 Notebook
Want To Replacing My Toshiba A10-S330 Hard Disk
Normally you can upgrade to a new hard disk to the next bigger size, so from 40 Gb, then perhaps a 60 or even an 80 would work. Even if the BIOS/motherboard would not recognized the new size, Windows XP would and be able to access it.
However, I don't think that the size should really be the main concern. I think that your selection should be based primarily on the power consumption. Most laptops have a preset power distributed to its devices. If you are going to use a bigger size HD with a bigger power consumption, Windows (or even your BIOS) might recognize it but the power distribution might be over worked.
My suggestion would then be go to the next size but keep in mind the power rating/consumption of the old when selecting.
I am enclosing an image of my laptop's HD. Pls note the rating DC+5V 0.7A for this 60Gb HD. The 0.7A is its current consumption/rating.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 12, 2007 | Toshiba Satellite A10 Notebook
Toshiba Satellite A10 Notebook Logo
333 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
