Question about Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
Electrical amperage required - Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
  • 52 Answers
I = E/R
Posted on Feb 25, 2010
Electrical requirements
Wire size is dependent on amperage carried by wire.
Jan 05, 2017 | Cars & Trucks
Tip
Battery Testing
Batteries can be measured with a volt meter, this usually gives a reading in volts such as 11.5 or 12.0. The voltage reading will not indicate battery condition.
All electrical requirements are established in amperes. Amperage of a battery can not be determined with a volt meter. The battery is a storage of amperage, however in order to measure this amperage it must be on the move, meaning operating something that requires power.
The only way to determine battery condition is by the use of a load tester. A load tester basically shorts the positive side of the battery to the negative side of the battery through a large resistor, this measures the amperage inside the battery, thus giving battery condition.
You can and will get readings, from a volt meter, anywhere from 10.5 to 12.0 volts on a bad battery. So if you suspect you have a bad battery, have it load tested to determine it true condition.
on Mar 27, 2009 | 1999 Ford Escort
I have oval pet fountain and need a power cord replacement. Can I get one?
the cord for this looks to be a DC voltage transformer, you can buy universal voltage adapters from any good electrical store.
the voltage and amperage required should be stamped on the appliance. the VOLTAGE must be the same, the AMPERAGE must not be lower than the required AMPs you can get an adapter that is rater higher without problem, but the VOLTAGE must be the same.
Feb 16, 2016 | Whisker City Corner Pet Fountain CORNER...
Could a Nissan Ga15 distributor work on a Ga13 engine
Typically you need to replace with the exact same make/ model or the voltage/ amperage output will not match your vehicle's required specifications, possibly causing damage to the battery and other electrical systems and sensors.
Oct 08, 2015 | Nissan Cars & Trucks
Bmw electrical
Sounds like a solenoid failure, remove the starter and have it tested.
Jul 22, 2013 | BMW Cars & Trucks
How do I make a 220 volt outlet where there is only 110?
what you need too find out is what is the amperage of the 220 oven and may have to run the proper size wire rated for the amperage back to electric panel to the proper size breaker the info should be on the name plate
May 26, 2013 | Leviton 15A Decora Electrical Outlet Light...
Manuel for whirlpool rje385pn self cleaning oven
What is the electrical specifications // amperage requirements for the RJE385PN
Feb 13, 2013 | Whirlpool Ovens
What does a junction block fuse operate in a 97 taurus
Power Distribution Center (underhood) is a main electrical junction box; most electrical components are supplied and protected though this box. If an electrical component short circuits it will blow a fuse in this box in most cases. The control relay and micro control relay are used as a high amperage switch for devices that require high amounts of amperage for an extended amount of time. The fuse or fusible link supply voltage to sub electrical systems.
If you need fuse diagrams or additional details about fuses on Ford Taurus, just contact us.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 07, 2011 | 1998 Ford Taurus
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
May 13, 2009 | Jenn-Air JGC8430 Gas Cooktop
30amp trip after getting hot
Look on the unit for the electrical data plate. It should have the required amperage rating on it.
Have the actual amperage being pulled by the unit checked.
You may have improper voltage being supplied to the unit which causes excessive amperage.
The breaker could be weak. Meaning that it may be tripping at an amperage less than 30.
Your wire size may be too small for the circuit which would cause overheating of the circuit and tripping the breaker.
Do not change the breaker to a higher amperage unless the wire size attached to that circuit is rated for it.
A breakers job is to stop power should a overheating of circuit or a short circuit occurs. It protects the circuit from catching fire inside the walls and burning the place down.
Good Luck and I hope this helps.
Mar 08, 2009 | Maytag Dryers
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Logo
69 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
