Question about Microsoft Xbox 360 Console
Keeps reeding open tray - Microsoft Xbox 360 Console
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
This sounds like you have a faulty laser in your DVD drive and is really difficult to fix you have done this before, if your console is still under warranty then please follow the link below to register your console and book it in for a FREE repair
https://service.xbox.com/servicehome.aspx?mkt=en-gb
Posted on Feb 01, 2010
I keep getting a speed error message when I start the belt
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
Precor Error Code LS
Dec 08, 2014 | Precor Exercise & Fitness
2003 kx250 why my reed petals keep going bad?
A reed valve in a 2 stroke engine is basically a way to prevent the fuel/air mixture from being blown back into the carb. If yours keep failing, the most likely reason is that you have bought cheap reeds. There should also be a reed valve support on the carb side. this is to stop the valve from vibrating and bending the wrong way.
Apr 24, 2013 | Motorcycles
Oil is being pulled from valve cover to air filter on my onan microquiet 4000 generator, what do I need to do?
63525c2e-e749-4a53-8402-d0463bb6c753.jpgThat sounds like the reed valve sticking or dirty.
You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
Aug 22, 2012 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Several of the reeds stick, producing no sound until suddenly the reed pops and the note plays (although not always with the correct tone). This problem usually doesn't occur until I play the note...
First and foremost i recommend you take your harmonica to a professional for repair. But the problem can be many things that you can fix with a little patience. FIrst youll need to open up your harmonica and look at the condition of the reeds(the plate with the slits.) If they are rusted or warped they have been poorly maintained as water will rust the metal(saliva.) Sometimes simple sanding solves this problem though it seems thats not your problem. Usually the reed is misaligned due to excessive use and a professional would fix this with an index card sliding it very slowly under each tip of the reed attempting to level out the small piece of metal. Your attempting to realign the reed with the entire board. To see if your fix has worked you can blow into the reed and see if a smooth vibration comes out. Any more complex solutions would honestly show that its time for either a new reed plate or a new harmonica. For future reference make sure to get all saliva out of your harmonica when done playing it and keeping it in its case. Good luck
Sep 12, 2011 | Hohner 280/64 Chromonica 64 Chromatic...
My 1989 rm 250 has just had a rebuild and is running fine but it wont go into the band
If you are referring to the power band,this is when your reed valves open.Check for cracked or damaged reeds.You need to remove carb and reeds are between carb and cylender.Check also the rubber boot that carb attaches to for cracks.this will cause intake air leak and cause reeds to not open properly.
Mar 21, 2011 | 2003 Suzuki RM 250
I had a tray problem at first it wouldnt stay closed fixed that but now it just says its reeding and to open tray
Id your system is not reading your discs the sensors on the back of the drive are taking too much heat use a good repair guide or send it in for a fix.
Sep 07, 2010 | Microsoft Xbox 360 Console
Keeps asking to close tray then opn tray
You can check the Open Tray error troubleshooting tip i have put on FixYa, check the link here.
Happy Gaming, please do take time to rate my solution
Regards
KreativeGeek
May 15, 2010 | Microsoft Xbox 360 Console
When I press the Eject Button on the Bose 321 DVD Player the tray does not open up. I can hear the sound as if trying to open
normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
it may also help if you can keep the bose 321 vertical.
May 30, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Akai DVD recorder tray will not open
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Aug 08, 2006 | Akai DVDRW120 DVD Recorder
Microsoft Xbox 360 Console Logo
215 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
