Question about Mantis Gas Mini Tiller/Cultivator, 2 - Cycle
Mantis tiller 2 cycle will not accelerate. idles fine accelerate it stalls. Already replaced fuel filter, cleaned air filter, replaced gas, replaced spark plug. Only has about 20 hours on it.
  • 677 Answers
I would pull the tines off of the transmission. You probably have some debris wrapped around the transmission drive shaft(s).
Please let me know.
Posted on Feb 08, 2010
Mantis tiller Idles fine, and can even rev... sometimes, but has no power.
check the diaphragm in the carburetor making sure it isn't stiff. depending on how long it has sat, the carburetor may need a cleaning and kit then readjust it to get it to run. Mantis tillers are very temperamental and can be difficult to get to run again even for experienced technicians
Feb 25, 2013 | Mantis 2-Cycle Tiller
Mantis tiller starts rt up, good idle no power,new fuel lines plug,filters,rebuilt carb,when trying to rev bubbles in gas tank?
Check that the fuel filter is sitting near the bottom of the tank, and not somehow being held near the top of the tank.
Jun 11, 2012 | Mantis 2-Cycle Tiller
Can not find my manual for the mantis tiller..forgot hot to start it up for the first time
You should be able to go to the Mantis web site and download the owners manual. To start, make sure the switch in turned on, push the fuel primer bulb several times (until you feel resistance), pull the choke out all the way and pull the starter rope until it fires. Then, push the choke half way in and it should start. Let it run a 30 seconds to 1 minute and then push the choke all the way in. Be sure you are using the currect fuel/oil mixture with fresh gas and oil. If you have not done so already clean the air filter and replace the spark plug at the recommended interval.
May 23, 2011 | Mantis 2-Cycle Tiller
Engine stalls out after 15 to 20 seconds of run time
get a carb kit new fuel lines.new fuel filter, air filter clean the tank and carb install new filters and fuel lines and you should be good... or you could first try pouring the gas in a clean clear container and see if you have water sitting in the bottom, then you could get a way w changing the gas you might have to let it stall out on you a couple times before you get rid of the water in the lines and carb run it on a littl less than 3/4 choke.
Jul 02, 2010 | Mantis 2-Cycle Tiller
Mantis tiller keeps shutting off
One screw is fuel and one is air, try turning the screws in all the way then open three turns and start from there.
Apr 07, 2010 | Mantis 2-Cycle Tiller
Difficulty adjusting carb for smooth idle and full power tilling
Your quickest fix for this problem is to simply replace the carburetor, a Zama K54A. Do it all the time. After that, if you can find a 2 cycle oil, Opti-2, it's the best you can use and it's a one mix for all your 2 cycle equipment (blowers, trimmers, chainsaws, etc.) It's the only 2 cycle I sell in my shop.
Apr 05, 2009 | Mantis 2-Cycle Tiller
Mantis Gas Mini Tiller/Cultivator, 2 - Cycle Logo
810 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
