Question about ViewSonic VE155b 15" LCD Monitor
Monitor says burn -in
When monitor is turned up monitor says Burn-in and then it just cycles through different colours. Cant get it to stop.
  • qteepahtutee May 24, 2008
    When I turn the monitor on, the display says Burn-in and then it just cycles through different colours. Cant get it to stop.
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
What do i do when the dialogue box reads 'cable disconnected burn in mode'
Get monitor out of burn in mode by unplugging the power to monitor then while holding down the power button on monitor plugged in the power cord to the monitor all while it is connected to a running computer. Turn the monitor off with the power button. When press the power again the burn in mode should be gone and the monitor should display the computer
Apr 24, 2015 | Sony SDM-HS73P 17" LCD Monitor
I have a colouredge Eizo CG246 monitor. the hewlett packard HP logo is frozen on the screen. i checked all cables and rebooted monitor but still cant get past this logo on the screen. any ideas anyone?
How old is the monitor? Is this a burn-in problem? If not, check the monitor settings to see if there is a video input from the computer. Check the monitor with another computer, and the computer with a different monitor.
Oct 16, 2013 | Computers & Internet
If I have an LG LCD screen being used for my CCTV system ideally I want it left on. Will the screen burn like a Plasma of will if be ok left on all the time?
all t.v`s plasma lcd crt will burn an image if left for long enough idealy you should get a moniter for cctv system as they are built for the job
Hope this helps
John
Mar 03, 2011 | Computers & Internet
Dryer will heat when put on 70 minute cycle but will not heat total time. if you put it on 20 minute cycle will not heat at all.
Hi, Some dryers have a cooling cycle that lasts for 20 minutes to cool the drum and its contents so you don't burn yourself when getting clothes out.
alot of machine have a max drying time of 120 minutes 20 of that will be for cooling so 100 mins hot!
the cooling cycle is usually indicated near the end of the dial in a different colour to that of the hot cycle.
Hope this helps.
Feb 11, 2011 | Dryers
The monitor turns black immediately after power cycle
i think it can be the capacitor problem, open monitor an look for swollen capacitors. if you will find them swollen or mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:IT;} @page Section1 {size:8.5in 11.0in; margin:56.7pt 42.5pt 56.7pt 85.05pt; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} loosing the electrolyte, signs of burn, change them
Apr 12, 2009 | LG 22" FLATRON LCD Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Smelling fumes from 4xl55. Also cycles many times b4 igniting.
Hi jim if you are smelling fumes turn it off and get a service done on it asap
Mar 27, 2009 | Dayton Gas Furnace Heater
Dell monitor flashing different colours and buttons won't work!
Go into your monitors settings and select "Factory Reset" Then go to "Factory" and you will find the burn in setting. Turn burn in to off. This should fix the problem.
Jan 08, 2009 | Dell E176FP 17" LCD Monitor
Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Dec 10, 2007 | BenQ FP71E 17" LCD Monitor
Two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Sep 24, 2006 | Samsung Syncmaster 730B 17" Flat Panel LCD...
ViewSonic VE155b 15" LCD Monitor Logo
174 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
