Question about Reddy R60A Utility Heater
CAN I PUT DIESEL IN MY KERO REDDY HEATER 150,000 BTU HEATER AND WILL IT SMELL OR RUIN IT
  • 3 Answers
Yes if it is NO#1 DIESEL
Posted on Jan 31, 2010
    Scholar:
  • 185 Answers
Since the combustion temp of diesel is different from KERO, expect the heater to shut down from overheating at times.
since it will probably heat up faster than on KERO.
Will diesel fuel substitute for number 1 heating oil. cant by that around here
Yes, you can burn diesel in there but... you will have more trouble with the heater... it burns crappy and soots everything up...actually the best thing to burn is K-1 Kero in them... that burns the cleanest... and it won't gel in really cold temps...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 08, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Can diesel fuel be used instead of kerosene?
Hello,Yes but it might be slightly smokey.I have used kero in place of diesel with good results.
Oct 30, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Is it okay to burn Premium Diesel instead of Kero? Also, will I have a stronger odor problem with the premium instead of kero?
yes its ok, just make sure the air pressure pump is dialed in right. With the right air pressure the heater will perform at its best and burn as clean as it can. Its the slotted set screw (plastic usually) on the back next to the air filter. Turn it in 1/4 turn at a time till the nose cone is almost all red or orange in color. This will give you the cleanest burn. Then adjust doors/windows for fresh air as needed. Hope this helps
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
I changed filters,but still get eye burning smell,I do use Kerosene
In my experience, eye burning is a by product of burning even the best kero. And at 115,000, you are burning a lot.
Jan 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Does not light sometimes smell kero and have to reset and then it will work
Sounds like the optical EYE is dirty. It sits right below the fuel nozzel. remove it clean it and reinstall it. 50 cents says it will light, prividing you have spark and fuel.
Jan 01, 2010 | Reddy Heater R70 Portable Forced Air Space...
Where can I get a pressure gauge to adjust the kero heater pressure ..... the kero odor is bad
go to mcmaster-carr industrial supply. the air pressure should be around 3-5 psi on that heater.
Oct 12, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heater won't start properly
Remove the nozzle from heater and clean, be carefull around the ignitor.
Dec 31, 2008 | Desa International Reddy Heater R40 40,000...
Reddy R60A Utility Heater Logo
259 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
