Question about THQ The Lawnmower Man
Fuel leak on my eager1 6.75 hp mower transported from CO to CA
My eager1 6.75 hp mower was transported from CO to CA. They drained the gas from it, and now when I try to fill gas into the tank, it leaks profusely from the bowl below the primer pump. The nut on the bowl seems very tight. Bad gasket? Does the bowl come off via that bolt alone?
Thanks, Jeff
  • 20 Answers
Yep, Yep.
Posted on Feb 17, 2010
Gas leaking into carburator when shut down
The fuel solenoid needs replaced. I put a fuel shutoff in.
Jun 16, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a model # 917.289720 mower. It dies while cutting. Just did a tune up, fresh gas, new fuel fiter, spark plugs, air filter. HELP !
Take off carb and clean it assuring ports and orifices are not plugged, its starving for gas ! Main jet. Water bubbles in gas? in bowl? Drain.
Apr 10, 2013 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
My mower will run for about 30 minutes then die and then have to wait for awhile and process starts all over. i have changed oil, spark plug, plug wire and coil, fuel filter, air filter and screen,...
Try this.
When the mower is about to die, loosen the gas cap.
My mower gas cap vent holes plugged up and kept stalling the mower.
If it works, drill out the vent holes.
Gary
Jun 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman 17.5 hp tractor that will start but soon cuts off. I have replaced gas. battery fuel filter and spark plug. Also burning a lot of oil to me.Have replaced fuel lines also. Seems to not...
Could be a head gasket. I'd recommend a compression test or better yet a leak down test that will show where the leak is. Hope this helps. Please vote yes, thank you
Nov 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will not start. Gas drains completely from tank
The carb needs rebuilt. The needle and seat inside the carb is not sealing.This means eather the float is no good or dirt in the carb or both.
Sep 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 hp mower
check fuel line for colapse near frame rail common problem ? new hose from tank to fuel filter will fix it
Aug 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower motor
No it's sounds like the float in carb is stuck I've had 3 motors do this I put a fuel shut off in the line after I cleaned the carb out and rebuilt it. The problem is the gas breaking down an gumming up the float in carb. Drain the oil and an run some oil thur it to get the old gas out make sure you clean the carb out to.
Sep 20, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
THQ The Lawnmower Man Logo
81 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
William Wurtinger
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
