Question about Hasbro iDog Electronic Pet Dog
My i dog dance will not stop turning on and off repeatedly by itself. HELP?
    Problem Solver:
  • 12 Answers
You may have it on demo or repeat check to see if its off
Posted on Feb 17, 2010
Look underneath the head and you should see the button reset push it and it should be fine. If not put new batteries in it! Hope I helped
Posted on Jun 30, 2012
  • Lily Mamexel Tom Jun 30, 2012
I can't get my techpet to wirk
Instructions
    • 1 Check that the iDog is powered on if it doesn't respond to your commands. Press its nose to activate the toy.
    • 2 Verify that the iDog has fresh batteries installed if the dog doesn't turn on. Use a Phillips screwdriver to open the dog's battery compartment, located on the its right back leg. Insert two new AA-sized batteries according to the "+" and "-" symbols listed in the compartment.
    • 3 Inspect the iDog's connection to your iPod if it doesn't move and dance to your iPod's music. Plug the iDog's connector cable into your iPod. The cable end labeled "B" gets inserted into the headphone jack on your iPod. The opposite end goes into the front left leg of the iDog.
    • 4 Make sure your iPod is powered on if the toy is connected to the media player and is turned on, but not moving to the music. Your iPod may need recharged by connecting it to a computer with its included USB cable.
    • 5 Reset the iDog if it continually freezes or stops moving in the middle of a dance. Use the tip of a pen, paper clip or similar thin object to press the reset button located on the bottom of the toy's head.
Jan 20, 2013 | Toys
Singing dancing Santa won't stop dancing
My neighbor just gave me 1 of these... needed the adapter... 4.5 Volt 800 mA and be sure to get one where you can reverse the polarity if necessary. (polarity is: + ---O---- - ) I had to do some "modifications" to the base as my adapter had an "L" base & wasn't long enough - straight adapter would have been better... Santa wouldn't stop singing/dancing- hmmm. Cleaned the motion sensor lens and then had to cover the modification hole in the base to completely darken the interior of the base. Viola now the motion sensor works... is driving the dog crazy!!
Nov 06, 2012 | Gemmy Life-Sized Animated Santa
Help my Mickey seems to be in demo mood, he won't dance or sing m to the i to the c...how can i fix him. all new batteries too.
Hi scottau
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
BEFORE YOU BEGIN
? Remove and discard the "Try Me" pull-tab, located on
Mickey's right foot next to the battery compartment.
Once the TRY ME pull tab is removed, the toy will
perform its full play pattern as described below.
? Be sure the ON/OFF switch is in the ON position.
The ON/OFF switch is also located on Mickey's right foot,
HOW TO PLAY
There are 2 places where you can press Mickey to begin play:
? LEFT HAND
? LEFT FOOT
Press either place to begin play.
There are 2 ways to play with Dance Star Mickey:
DANCE MODE
Press Mickey's foot to see him perform
one of 6 different dances!
? TECHNO
? MAMBO
? MOONDANCE
? "SHAKE YOUR GROOVE THING"
? "GET UP OFFA THAT THING"
? "M" TO THE "I"
GAME MODE
Press Mickey's hand to alternate between 2 games:
? Mickey says
Follow along and repeat Mickey's moves -
but only when he says "Mickey says!"
? Freeze dance
Dance to the beat when Mickey says "Go".
When he says "Stop", you freeze in place!
Jan 02, 2011 | Disney Fisher Price Dance Star Mickey...
Roomba is dancing?
You are stuck on spot clean. Try removing the battery and reset it then try Full clean.
Feb 14, 2010 | iRobot 4160 Roomba Robotic Vacuum
Vtech sit to stand dancing tower
ours did that too until we put new batteries in it.
Jun 09, 2009 | Vtech V Tech Sit To Stand Dancing Tower
Game stuck on same passed song
It's most likely tht you have a bad disc, if it's repeating itself...
Sorry!
Feb 15, 2009 | Konami Dance Dance Revolution Hottest...
Motion Won't Turn Off
The trick to this is to catch the dog while just playing the music and not while dancing. What this means is that his foot must be down and not moving. Very often he will pause dancing with his foot up, however this is considered "mid-cycle" and he will ignore his stop command. When his foot is down waggle the tail towards his rear. This will produce all but one light turning red and a little beep to indicate him ready for a command. While holding the tail push the nose button for about a second, not long enough to turn him off but more than a quick tap. If his foot is down and music is playing he should respond.
Dec 31, 2008 | Hasbro I-DOG AMP'D
The dancing
manual says while dog is playing music thru the cable and lights are flashing.... to press down the tail and while holding down tail to press the nose, but on my dog it only works like 1 out of 30 tries. Supposed to see spinning lights if you did it right. If dog growls at you it is not in the right mode (music play) to do this function.
Dec 11, 2008 | Hasbro I-DOG AMP'D
Hasbro iDog Electronic Pet Dog Logo
305 people viewed this question
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
