Question about Samsung HCL473W 47" Rear Projection Television
Samsung HCL473w picture distortion
Picture is curved and ditorted. Does not fix when reset using plug and play
  • reddragon68 Feb 26, 2008
    my father has a samsung HCL473W projection television, and i beleive that the colors are out of adjustment. we have tried to adjust them back by truning the lenses. it came close but there still was a green tint with a curve going through the middle of the screen. i was just curious if you might know how to fix the problem and make it picture perfect again?
  • f4xdrive May 11, 2010
    Just repaired my hcl473w TV ...Can you be more specific in your problem. Example: colors is off like a 3D movie needing glasses.
    Thanks,
    f4xdrive
    Novelist:
  • 132 Answers
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
This requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Posted on Sep 15, 2008
I have a HCL 473W that has a big red wave in it and the colour is all distorted. Anyone have any idea what that could mean? I hooked my nintendo up and could play the game but the colour and the wave still...
Ur tv have a convergence problems,it dead.U must know how do soldering,have soldering tools,and have solders to fix convergence problems.U must replaced the 2 STK Convergence ICS,and some or all it resistors on the Convergence board.Tries wesites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors
May 06, 2010 | Samsung HCL473W 47" Rear Projection...
Samsung HCL473w lamp
Call FOX 1-800-227-5369 they have Lamps
BP96-
Jan 02, 2010 | Samsung HCL473W 47" Rear Projection...
When recording and playing back the view screen is distorted with alternating lines.
If there is no problem when you play back on a different camera or computer, then the fault concerns LCD ribbon cable or lcd controller circuit on main pcb.
If the recorded image is also distorted on computer and different camcorder, then you have a faulty ccd sensor.
Also wiring problem and pcb fault sometimes can cause ditorted picture, in that case the problem is usually a kind of dirturbance and does not happen all the time.
Regards.
Jun 24, 2009 | Canon ZR830 Mini DV Digital Camcorder
Curved red lines on the screen and the picture is distorted
This is a convergence problem that can be either poor solder connections on the convergence ICs or defective ICs. If you can solder you can fix this yourself. Update this if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 23, 2009 | Samsung PCL545R 54" Rear Projection...
Picture is extremely distorted
generally Samsung makes great units. but its definitely not worth fixing. recycle it and indvest in a new unit.
mj
Dec 22, 2008 | Samsung DynaFlat TX-P2775H 27" TV
Samsung HCL473W 1080i red shadow & words are curved at top/bottom
I believe you have convergence problem on your rear projector TV. It require to replace may be 2 IC output convergence or the convergence drive, after replace those component you need to readjust convergence which mean you move the RED GREEN BLUE to be 1 on top each other you must have the remote control and service manual to get into the service mode, if you thing you can get those part in your country the service manual I may help you with that, ask your husband if he like to challenge it. I hope that is give you some ideas
Cheers
Dec 17, 2008 | Samsung - Projection TV replacement lamp...
Samsung Projection tv Blue line across the screen curving up
This set does not have a bulb. It is a tube type projection set that sounds like it has a convergence problem. Call a qualified tv repair company.
Jun 24, 2008 | Samsung - Projection TV replacement lamp...
I have a samsung HCL473W and curved blue lines have appeared on the sreen
Try turning down the blue G2 slightly if that doesnt help you will have to trouble shoot the blue crt drive circuit or possibly replace the blue CRT itself.
May 04, 2008 | Televison & Video
I need to really find an HCL473W tube, can you help me??
easyab
Apr 19, 2008 | Samsung HCL473W 47" Rear Projection...
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Samsung HCL473W 47" Rear Projection Television Logo
198 people viewed this question
Jerry Greenberg
Jerry Greenberg
