Question about Sony BDP-S300 Blu-Ray Disc Player
I have a surround sound and i cannot get the surround sound to work with my sony bdp-bx1 player I have the surround sound working with regular cd and dvd player and tv working fine
  • 4,472 Answers
A lot of information will be needed from you. First off what is the make and model of the surround sound system? Also what type of connection are you using from the blu ray to your surround sound? have you changed the options of the blu ray player at all to make sure it is outputting the audio that your looking for?
Please give me as much detail as possible so I can best assist you.
Thank you,
Lee
Posted on Jan 31, 2010
What code do i use for my One for all big easy URC-4330B03 to program it to my sony blueray dvd player BDP-BX1
Use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Feb 01, 2017 | Sony Televison & Video
How to program a dish remote to my Sony blu-Ray player BDP-BX1?
Do you have instructions for programming the remote? If so, One of the following codes should work.
20533, 21533, 20864, 21033, 21070, 21431, 21536.
Jul 29, 2015 | Sony Televison & Video
My sony bdp bx1 is updated and still can not play any universal and some Columbia and Fox discs
Will it play standard DVD discs, if yes there is a problem with the laser pickup assembly, blu-ray disc require greater precision and speed when playing these discs because of the higher resolution.
Apr 11, 2012 | Sony BDP-BX1 Blu-Ray Player
After update player will not turn on. I have verified that unit has power. model number BDP-N460
The problem with updates is if they don't do a good job of flashing the BIOS, it renders the unit worthless. If that's what happened, it's a repair shop fix.
Jun 25, 2011 | Sony BDP-BX1 Blu-Ray Player
Certain movie will not play /
You need to update the firmware. go to www.sonystyle.com then to support, type in your model #' and look for downloads. Complete instructions are given to the user as to the installation process. If you have difficulty, Contact Sony Support directly and they will send you the firmware updates on disc at N/C. Hope this helps
Jun 14, 2011 | Sony BDP-BX1 Blu-Ray Player
My Sony Blu Ray player BDP BX1 won't play any disc,blu ray or regular DVD ? Did the online software update.
I assume you tried the software update after the unit failed. If it quit working because of the firmware update, you may have received a corrupted file. In that case, try downloading a new copy on a different computer or to different media, and repeat the update.
If (assuming hardware problems and not bad firmware) it cannot play any optical disk, not even audio or photo CDs, I would suspect the laser in the optical drive has gone bad. Replacement is not a lot of work, but the part is probably about $50. I think it's likely this is the same part used in the Sony Playstation 3, which had some problems with lasers dying too soon when it first came out.
Here's a way to check: first, insert a DVD in the player. Unplug it and remove the top cover. Caution: do not tip the player with the DVD inside. CAUTION. Directly viewing the laser can cause severe damage to your vision. DO NOT put your face over the DVD drive - ever - while it is plugged in. Observe it from the front, a little off to one side. Before plugging in, check the ceiling overhead and make sure there are no mirror-finish or glassy reflecting objects above the player. The DVD must be in first for safety reasons; it covers the laser. The rest is additional precaution.
Now, plug in and turn on the player. In normal operation, the laser comes on, and the lens moves up and down to focus on the disk. You may see a blue glow in the center of the disk (especially in a dark room). If the laser is working and the laser/lens assembly is able to obtain a focus, the disk will start spinning. If the disk does not spin, the laser/lens assembly is the first suspect. It is also possible that the spindle motor drive is bad, but given the history of PS3 Blu-Ray drives...
If there is no movement of the lens assembly, check the power supply. If it is good, there is (by elimination) another problem with the lens assembly (controller problems, to the best of my knowledge, are rare). Because it has very tight assembly tolerances, the lens assembly is usually replaced as a unit rather than repaired in the field.
Oct 16, 2010 | Sony BDP-BX1 Blu-Ray Player
My Sony BDP-BX1 Blue Ray remote stopped working. I have replaced the batteries several times, but it does not work.
Check whether the remote is sending a signal by using a digital camera, still or video. While looking at the LCD screen of the camera, point it at the remote which someone else is pushing buttons on. If you see the (infrared) diode flashing on the remote, you know it's working and there is a problem in the BlueRay player.
If there's no flashing, the most common problem with remotes is the timing crystal inside breaking free of the circuit board, or maybe just a cracked solder joint to the crystal. Get someone who can solder to take the remote apart and check for this possibility.
Apr 18, 2010 | Sony Televison & Video
Our blu ray is saying unknown when we put a disc in it
This model is Sony factory service only. GO to Sony.com support and get address to send it to. If under warr take it to where you boaght it and demand an exchange.
Nov 23, 2009 | Sony BDP-BX1 Blu-Ray Player
I lost the remote of my Sony BDP-BX1, and I cannot Play the movie
right. well as far as i can see its as simple as getting a new remote. the problem with these is, no, they dont have many manual options. so unfortunately you will have to replace the remote
May 05, 2009 | Sony BDP-S300 Blu-Ray Disc Player
CMT-BX1 won't play CD's - "No Disc"
If they're clean (i.e. not scratched up or dirty) store-bought CDs (burnt CDs can be iffy in some players), then yes you should return it.
Sep 16, 2007 | Sony CMT-BX1 Shelf System
Sony BDP-S300 Blu-Ray Disc Player Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
