Question about Gateway 450ROG Notebook
Gateway 450ROG Laptop was downloading a video when the screen slowly went all white. I had to power off. I waited a while reloaded the battery and powered up. I got the windows didn't power down right. Windows will start normally in 30 sec.(unless you choose safe mode) It started up , got to where it loaded my desktop, but then stopped no start button or icons across the bottom of the screen. Then it started to slowly turn white. I powered down, unplugged power cord, removed battery, held power button for 15 sec and replaced battery and plugged back into electrical power. It showed the reovery screen again. Windows welcome screen came up but that was all, which took unusually long to load. Then it slowly turned white again. I powered down.
  • 1 more comment
  • Canei Jan 31, 2010
    I can't even get into the safe mode. That recovery screen shows but I can't access it.
  • 62 Answers
You must go through the safe mode and uninstall your graphics driver and install another one, may be you will find more compatible driver with your graphics card and your windows copy on gateway website.
Posted on Jan 31, 2010
There is a password on the cemos i need to clean it because it can't boot on the cd rom GATEWAY 450ROG
you need to reset cmos, cmos reset located inside the laptop this can be in different places from laptop to laptop. watch the video
Dec 18, 2010 | Gateway 450ROG Notebook
Gateway 450ROG, will not start. Red DVD/CD ROM
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Mar 31, 2010 | Gateway 450ROG Notebook
Gateway 450ROG audio stopped working after connecting to TV
Go into Start / control panel / sounds / and see if any drivers are showing, if not then re-install, Go to vendors site to download driver for your laptop.
Just remembered little tip, can you see the speaker at lower right of screen, if not driver may not be there especially if it was before.
Jan 20, 2010 | Gateway 450ROG Notebook
Screen is black
The cable is dislodged or you have a failing lcd.If you want to repair this yourself.Check online for a replacement cable and a Lcd too.Then you will have to open the Lcd Bazel to remove or check the cable.Make sure when you attempt this there is no power attached ,battery and Ac Adapter.
Good luck
Nov 02, 2009 | Gateway 450ROG Notebook
Gateway 450ROG screen went dark
Try using a can of compressed air and blowing out all the nooks and cranies. I did this and it worked for mine. Haven't had a problem since doing this. Let me know if you need more help.
Jun 19, 2009 | Gateway 450ROG Notebook
Gateway laptop- screen went dark but is still on.
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 31, 2009 | Gateway 450ROG Notebook
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Apr 10, 2009 | Gateway 40G / 40GB for laptops /...
Gateway 450 ROG Dispaly
then it sounds to me as if the interface cable/connector is loose or damaged for the video feed to monitor screen itself might try to check or have some one to ,it could be bad monitor also but i would ck interface first ,also a couple of other things to try is reload drivers from hp and see if makes a difference , also the video output board could crapped
Jan 12, 2009 | Gateway 450ROG 15inch SXGA+ LCD Display-...
CMOS BATTERY
Gateway 450ROG CMOS BatterySmall internal battery that maintains calendar and clock settings.
PLEASE NOTE: This is not the battery that powers your laptop; it only maintains certain internal settings. If you need a main battery, please refer to the page on our web site for your laptop model.
CMOS batteries are located on the motherboard; if you are not comfortable with the inner workings of your laptop, you may want to consider having the battery installed by a qualified technician.
Here is the link to their site for your cmos battery
http://www.gatewaylaptopparts.com/shopexd.asp?id=1082
Feb 25, 2008 | Gateway 450ROG Notebook
Gateway 450ROG Notebook Logo
126 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
