Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Says lamp problems - Panasonic PT-50LC13 50" Rear Projection HDTV
  • 1,476 Answers
Without more information it is going to be hard to help you. I assume you mean the TV has a warning of lamp problems. Means you need to replace the lamp. Go to www.partstore.com and put in your sets information. You should be able to find the lamp you need. Get it. Your owners manual should tell you how to replace or at least where the lamp housing is. Open the housing, remove the old lamp, install the new lamp, close properly and you should be good to go. Let me know how it works out.
hardrocko
Posted on Jan 31, 2010
How to solve the problem error A100 on km 1510
Exposure lamp problem
• Check the CCD input value for the lighting status of the exposure lamp 100 ms after the exposure lamp is lit and the carriage is moved to the shading position. If the exposure lamp does not light, turn off the lamp. After 500 ms, light the lamp again and, a further 500 ms later, check the CCD input. The exposure lamp does not light after 5 retries
causes
Poor contact of the connector terminals. Defective exposure lamp. Defective main PCB or inverter PCB. Incorrect shading position. CCD PCB output problem.
Jul 26, 2014 | Office Equipment & Supplies
IN5532, problem: Indicator power on (green) Indicator service: on (red) Indicator lamp: blingking (red) Please, what kind of this problem indicated? And how to fixed? Thanks
Power - green - is good.
Service - red - is not so good
Lamp - blinking red - is not so good
For dual-lamp projectors, one blink off every 2
seconds means the problem is with lamp #1; two blinks off
every 2 seconds means the problem is with lamp #2.
So how many lamp blinks do you have?
Mar 19, 2011 | InFocus IN5532 Projector
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
Sony kdf e50 a60 when TV is turned on picture goes off almost immedately and red light starts blinking in stand by mode.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
  1. Outside lamp cover
  2. Lamp door
  3. Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
  1. Remove the outside lamp cover.
  2. Remove the lamp door.
  3. Pullout the lamp
  4. Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
  5. Mount the new lamp securely.
  6. Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
  7. Put the outside lamp cover back in its place.
or visit http://www.fixya.com/support/t2631342-need_replace_42_in_sony_wega_hdtv
Aug 11, 2009 | Televison & Video
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
SP-LAMP-LP3E powers off in 5-20 secs after inital power on
if the new lamp doesn't have a problem, then it's not the ballast, it's just a bad bulb. especially if you didn't get it from infocus. the cheaper lamps don't last long. you get what you pay for.
Dec 23, 2008 | InFocus Projector Lamp for LP340, LP340B,...
KDS 50A2000 red lamp light blinking 2 times
Did you use an original Sony lamp? If so, I would say that the problem lies with your lamp ballast, or lamp power supply. Also, keep in mind that, although rare, occasionally the lamp power supply will fail in such a way that it will take out the lamp and any other lamp that is put in. So if your new lamp is blown, it is likely the lamp power supply that is at fault and you will require a new lamp as well.
Dec 10, 2008 | Sony KDS-50A2000 50" HDTV
New replacement lamp ty-la 100rl not working
If you place order for Panasonic lamp again this time, I think you would not face this problem as in past you had no problem.
Sep 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
My projector keep shutting down
After replace the lamp. Please reset the lamp hours and clean the filter. It should work.
Apr 07, 2008 | Office Equipment & Supplies
Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Mar 21, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
77 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
