Question about Kenmore 87562 Dryer
This dryere is overheating and the vents free of debris. What else could be causing it?
    President:
  • 2,468 Answers
Check the cycling switch in the element case,it turn on and off the element as needed for heat,you can remove wires and check it with a continuity tester,it should show continuity ,then heat it with a match and listen for a click sound,then you should show infinity on the meter or open,its just a bi-metal switch
Posted on Feb 03, 2010
Hi I have a Simpson 4kg eziloader dryer that keeps tripping the power mains . Would this be the timer ?
The heating element uses the most power. Was the home wired by a licensed election ( the dryer plug)? if it was it should have #8 or #10 wire depending on the load. the breaker is sized to the wire (so don't change it). you may have a clogged vent pipe. this will reduce air flow and make the dryer work harder possibly tripping the breaker. You should probably start by making sure you vent is clear and free from debris, debris in the vent could cause a fire.
Sep 10, 2014 | Dryers
I have a frigidare dryer 5-6 years old. Recently, started smelling like something electrical is burning. If I hold down the start button the motor will turn the drum slowly and the burning smell returns....
Check for vent blockages! Overheating may be a serious issue and fire hazzard. A slow moving drum could mean a bad traction belt, jammed mechanical part or the motor is not spinning at a proper RPM which may indicate motor damage also. The electrical burning is a serious issue also and a fire hazzard. Dryers need periodical cleaning to remove excess lint, dust and debris. Lack of cleaning causes the dryer to work harder and run hotter. Excessive heat shortens the life of many parts such as belts, bearings, electronics, wiring, etc...
Sep 21, 2012 | Dryers
Dryer drum loose not lining up properly making a huge thumping sound
Identification of Dryer Problems
Signs that an electric dryer may need some repairs include the dryer not heating, clothing not drying fast enough, overheating of the dryer, the door not locking shut and the dryer not starting at all. Any of these are signs of an underlying problem that can usually be solved without the help of a repairman.
Effects of Dryer Issues
If an electric dryer doesn't heat properly, it prevents the clothing from becoming dry in most cases. Restricted venting can cause clothing not to dry fast enough, as the dryer will cycle the heating. Overheating dryers can ruin clothing or cause burns. If the door on a dryer wont close, it is impossible to get any laundry dried. A dryer not running at all can be very frustrating and lead to owners needing to use a laundromat.
Considerations for Solving Common Problems.If the dryer wont heat up, owners should check the circuit breaker to see if it's down. The voltmeter at the wall plug should read 240 volts. Checking the power cord can show owners if the wires are burned where they meet the dryer.Clothing not drying fast enough and overheating are signs of restricted venting. Removing the vent hose from the dryer can help owners decide if this is the cause of clothing not drying. If the hose is removed and the dryer runs normally, the vent should be cleaned.White plastic or thin foil ducts can also lead to overheating. Only metal ducts should be used with dryers. Kinks in the vent hose can also lead to heating issues. Overheating can also be caused by a shorted heater coil, a bad operating thermostat or worn drum seals.If the door on an electric dryer will not close, it is usually a problem with the door catch. This can be solved easily by purchasing a replacement door catch for the dryer.
When a dryer wont run, it could be a number of issues. The circuit breaker may be down or the wires at the plug may be burned. It may be an issue with the door switch. The door switch should click when closed. The thermal fuse should be checked for any issues.
Preventing Dryer Problems
The electric heating element, thermostats, fuses and thermal cut-off should be checked regularly for continuity. Dryer vents should not exceed 18 feet without a helper blower in the duct. Vents that are run vertically need to be cleaned out once a year. A meter can be purchased and used to diagnose problems with your electric dryer.
Warnings and Tips.Inexperienced people should never try to fix electrical problems at home. A professional should always be used if dryer owners suspect a more serious problem. Dryer owners can purchase kits to make cleaning dryer vents easier.
Mar 11, 2011 | Whirlpool Dryers
Our dryer keeps overheating and then shutting off with an e66 service code. we have had a reputable repair man out twice. he replaces numerous parts but then the dryer did the same thing after 4 uses. we...
Instructions
Things You'll Need:
* Owner's manual
* Screwdriver
* Lint bags
Troubleshooting Your Dryer
1. Check the area around the exhaust vent of your dryer. One of the most common causes of dryer problems, including overheating, failing to dry clothes properly and not heating up properly, is that the exhaust has been blocked by dirt, lint, and other debris. In addition, the cheap vent hoses that come with many Electrolux dryers are not adequate for the job, and it is a good idea to replace those vent hoses with higher quality stainless steel replacement hoses. In the meantime, be sure to check the entire length of the vent hose for blockage, removing any kinks as you go.
2. Check the thermal fuse. Many models of Electrolux dryers are equipped with a thermal fuse, and if this thermal fuse is faulty, the dryer may not run at all, or it may run but not generate any heat. Consult your owner's manual for the location of the thermal fuse on your dryer model. On many models, the thermal fuse is located inside the back cover panel; you may need a screwdriver to access this panel. Be sure to unplug the dryer before you get started. If the thermal fuse is blown, be sure to replace it and try to run the dryer again.
3. Check the power cord running to the dryer. If the cord is frayed or damaged it could cause the unit to short out and not run properly. If the cord is damaged, the dryer may run sometimes, but refuse to start at other times. Be sure to check the entire length of the cord, from the point where it attaches to the dryer itself to the point where it plugs into the wall. If the cord is frayed, cut, or damaged it will need to be replaced before you attempt to use the dryer again.
Feb 28, 2011 | Electrolux EIED55H Dryer
Why is my Whirlpool Cabrio dryer saying AF instead of the Mins.?
Thank you for contacting Fixya.com.
According to the manual....
"AF (low airflow condition):
The dryer will continue to run when this diagnostic code is present. Press any key to clear the code from the display and return to the estimated time remaining.
Try the following:
1. Clean lint screen.
2. Check to see if the vent run from the dryer to the wall is crushed or kinked.
3. Confirm the vent run from the dryer to the wall is free of lint and debris.
4. Confirm the exterior vent exhaust hood is free of lint and debris.
5. Confirm your vent system falls within the recommended run length and number of elbows for the type of vent you are using.
6. Select a Timed Dry heated cycle, and restart the dryer.
7. If the message persists, have your entire home venting run cleaned."
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Dryers
What does it mean when my dryer flashes the letters "af"
Your dryer vent may be crushed or blocked. To resolve this issue:
,Check to see if the vent run from the dryer to the wall is crushed.
Confirm that the vent run from the dryer to the wall is free of lint and debris.
Confirm that the exterior vent exhaust hood is free of lint and debris.
Confirm that your vent system falls within the recommended run length and number of elbows for the type of vent you are using. Refer to the "Plan Vent
System" section of the Use and Care Guide for details.
Apr 04, 2010 | Kenmore 67082 Electric Dryer
My dryer is overheating, causing my thermal to blow. The dryer vents are clean. What could be causing this?
All dryer heat functions are controlled by thermostats:
Check all thermostats and make sure they all are lint and dust free, if problem continues, change the high limit thermostat which is the unit that controls high temperature and might be defective.
GOOD LUCK!
Aug 30, 2009 | Dryers
Dryer is overheating and tripping the breaker after 40 minutes
Is the dryer tub turning as fast as it should? If not the dryer motor bearings or sleeves may be trying to seize causing the motor to decrease in speed therefore the lack of fan action will cause the dryer to overheat.
Apr 07, 2009 | GE DBXR463EDWW Electric Dryer
Dryer doenst stay hot
It is possible that it is the high limit, make sure that the vent is free of debris ie lint. Also confirm that the blower fan is turning that blows the air out of the vent. if thd vent is clogged it will cause the high limit to open and also the high limit will open if the vent blower is not turning.
Mar 07, 2009 | Amana NDE2335AY Electric Dryer
Laundry taking too long to dry!
1. Make sure the filter is clean. A clean filter allows for proper air circulation in the dryer.
2. Make sure the rear dryer vent is clean. Move the dryer, unplug it and remove the rear vent hose and clean out any debris from the vent, in the hose and any debris in the outside vent.
Over time, these things get clogged and reduces the air circulation in the dryer, causing it to take longer for the clothes to dry.
Please let me know if I can be of further assistance to you.
- Jim
Feb 14, 2008 | Dryers
Dryers Logo
65 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
