Question about Philips Magnavox DVD/VCR Dual Player
Setting up DVD/VCR
I am to set up my Phillips DVD/VCR. It is hooked up to a Phillips TV. The instructions say to press the DVD button on the remote control, then press theSet Up/Menu button and the main menu will show up on the screen. I am not getting the main menu.
Do I have to have the TV on a certain channel?
The model numbers for the TV and DVD player are: DVP3340V/17
and 19PFL5422D/27.
Thank you for your help
  • Anonymous Feb 18, 2008
    my dvd player plays but i cant get it two play through the tv i have tried diffrent channels but it still wont play on the tv what do i do
  • Anonymous May 16, 2008
    I have an LCD TV. I wish to run the TV sound through my Harmon Karmon Stereo tuner. I also wish to view the DVDs from my Phillips DVD Player on the TV screen but wish to re-rout the sound through the Stereo tuner. The Avion LCD TV is equipped with IN connections but no OUTs.
    Comcast told me to rent a TV box which is equipped with OUTs and connect the accessories in this manner. Any suggestions?
    Problem Solver:
  • 9 Answers
My suggestion is this:
1. Connect the composite AV cable on the DVD player's DVD/VCR OUT and on the TV's AV2 or on the side. Select AV2 on the TV by pressing the SOURCE button on the TV remote control. Select SIDE if you connected it to the side. When the DVD player is on and set to DVD mode, you will see the Philips logo on your TV screen. You can then put it on VCR mode to set it up.
2. FOR RECORDING PURPOSES...since your DVD/VCR is tunerless, you will need an external tuner in the form of cable box or satellite box. You have to connect the cable/satellite box to the DVD/VCR also using composite cable. Connect another set of composite cables from the cable/satellite box's AV out and to the DVD/VCR's VCR IN.
Then you can follow the DVD/VCR's instructions for setting it up for recording.
Posted on May 18, 2008
  • 476 Answers
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Posted on Feb 24, 2008
  • David Simpson Feb 27, 2008
    How is the DVP3340 connected to the 19PFL5422D?
    If you are using the screw in coaxial connection (F-connector) then the DVD films and menus will not be displayed on the screen, as the DVD side of the player does not output through this connection.
    You will also need to use either:
    • YPbRb + stereo audio (red / green / blue component RCA + red / white RCA)
    • S-Video + stereo audio
    • Composite video + stereo audio (yellow RCA + red / white RCA)
    Then select the relevant AV1, AV2, AV3 or AV4 to display the picture.
    If this still doesn't help, then let me know exactly how the unit is connected.
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
Nov 29, 2016 | Universal Televison & Video
Why can't I find the codes for DirectTV remote?
The DirectTV remote should have the option to
scan for the code check the instructions for
the automatic scan method most likely you
turn on the tv, dvd/vcr keep pressing button
until channel changes or set turns off which
ever button you use if you dont have the
instructions try this address
http://www.satex.com/directv/remote_codes.html
Nov 22, 2007 | Polaroid FLM-3232 Television
How to setup phillips universal remote to a panasonic tv
More items...
Nov 29, 2016 | Panasonic Televison & Video
Owners guide GE VCR model VG2001
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Oct 16, 2014 | General Electric Vcr Remote Control...
Need code for a phillips universal remote for zenith tv/vcr model tvsc2040f
you can get the code automatically by pressing set button the remote then after keep pressing the volume key while you observe the tv for response once you notice any response press the set button again.now its ok.
Sep 24, 2010 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
Can't find the correct way to hook up my vcr to my dvd recorder to record vhs to dvd disc. could someone please give me some instuctions on hookup please. thanks
connect yellow, red, and white RCA jacks (video, audio rt and lt) to the "out" on the VCR. If your VCR isn't stereo it will only have one audio plug.
Connect the other end of the jacks 9yellow, red, and white) to the "in" jacks probably marked Aux in, on the DVD recorder.
Now follow the instructions on the DVD recorder to set to Aux in (some have two aux front and back). Should have a button for it on the remote.
With the dvd, tv , and vcr on, you should see the VCR on the screen. Start the tape and press record on the dvd, you are set.
Mar 02, 2010 | Televison & Video
NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
May 09, 2009 | Televison & Video
Teknique Jumbo Universal Remote Control Instructions
Pacific TV - Press "SET" and Hold it, press "TV" and release it, then release "SET", then type one of these codes 0676, 0677, 0678 or 0679. After each code try powering off the TV using the remote. One should work. (I think the 2nd one worked for me).
Jul 18, 2008 | Jensen JER-422 Universal Remote Control
Philips Magnavox DVD/VCR Dual Player Logo
399 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
