Question about Canon PowerShot SD1000 Digital Camera
My lcd screen will not show the picture. The
My lcd screen will not show the picture. The backlight is on, but the screen is blank
  • Canon Master
  • 4,738 Answers
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Posted on Feb 06, 2010
I have a LG 37LC46 lcd tv. Power is going through the set but no picture. Just error message "not programmed" and then blank screen. Happened very suddenly please can you help?
When the screen goes blank, dim the lights in the room. Take a bright flashlight and shine it on the panel. If you see a faint picture, you have a backlight failure
Jan 28, 2013 | LG 37LC7D 37 in. LCD HDTV
Turns on but has a blank screen
Show a torch light on the screen and see whether you can the picture. If yes, the backlight is not getting on. If no, try changing the input device to some other. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Half screen is blank 42lg20 or 42lg50 when
This is likely to be the T-con board. If the entire screen glows but you have no picture on the second half of the screen then it is the main board, not the backlight inverter. If the screen is half picture and half gray it is the T-con board.
Replacement of one of the above will fix the issue.
Please rate if this helped :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Protron PLTV-6 television. Has audio, shows picture very briefly when changing channels, then blank
The tv have a long board call the LCD inverter board.This long LCD inverter board is dead.This long LCD inverter board job is to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long LCD inverter board for the replacement.
Oct 18, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
Video comes on but I lose the picture in 3-5 minutes, screen goes blank.
U still have sound,when screen go black?Than ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 17, 2010 | Vizio L37 Television
Screen show no display/ only blank.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 27, 2009 | HP Pavilion dv6000z Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Laptop screen blanks out
Defective CCFL backlight may has the following symptom:
Apr 02, 2009 | EliteGroup ECS G900 Notebook
Laptop runs but screen stays blank
Apr 01, 2009 | HP Compaq Presario V6000T Notebook PC
Canon PowerShot SD1000 Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
