Question about Yamaha YHT-340 System
I have a 1980 yamaha enticer and it ran great yesturday and now today it wont start. what could be the problem?
Check the fuel line going from the cylnder to the fuel diafram the recoil rope could have wore threw it thats the problem i had
Posted on Dec 23, 2010
Take out spark plugs. Put some gas down the holes (about a tablespoon), Try and start it obviously with the plugs back in and the key on. If it starts you have a problem with the carb. Check fuel level, check for clogged filter, etc. sometimes just turning the carb jets a half turn either way may break free a small particle of dirt (always mark jets so they are put back where they belong). Also when the plugs are out make sure you still have spark by attaching to the spark plug wire and putting the spark plug on a bolt from the machine. Give it a pull and make sure you can see a good blue coloured spark on the electrode end. If not it may need new plugs.
try this stuff and see what happens. Good luck.
Posted on Dec 25, 2010
My headlight wont come on 1980 yamaha rs 500
Check fuses and bulb, if none, check wiring. It might not be as simple as seek and replace. It is a 1980 you know.
Feb 04, 2014 | Yamaha Motorcycles
How to separate front forks on 2005 yamaha enticer 125
Hi, Anonymous for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
FRONT FORK OF YAMAHA ENTICER SERIES
Yamaha YBR125 Fork tube replacment seal rebuild
Manual de Usuario Yamaha Enticer YBA 125
OEM parts for Yamaha
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 20, 2013 | Yamaha Motorcycles
I have an 81" yamaha enticer that we cleaned the carb on and put back on the sled which now runs great. The issue we are having now is that when the throttle is engaged the sled won't move. I assu
Clutches can be easily disassembled using the proper puller and spider removal tool, you will also need a holding fixture as the spider can be very tight.
Aug 17, 2017 | Winter Sports
I have a 1979 yamaha 340 enticer.Recently it would not start, no spark. I tried new plugs and a new ignition coil but still no spark. Don't know what to do next.
Hi, Gmgroot and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Security alarm failing to disarm needs reset
1999 royal venture no spark limited knowledge need help
https://www.tradebit.com/filedetail.php/55384194-yamaha-1983-1988-enticer-excell-340-snowmobile-service
http://vintagesleds.com/library/manuals/yamaha/1980/ET340_80.pdf
http://www.gearhead.com/snowmobile/parts/oem/yamaha.html?aribrand=YAM&s2=snowmobile
Feb 04, 2011 | 2000 Yamaha Royal Star Venture
Ran yesturday, tried today no fuel in lines, or pressure in rail, fuel pump not activating
Check the fuel pump fuse and relay under the hood in the fuse panel. If both fuse and relay are good then fuel pump may be at fault, but it seems too new for a fuel pump replacement. Hope this helps. Keep me posted please. Good luck
Apr 27, 2009 | 2005 Dodge Ram 1500
1995 s-10 blazer startin issues
it could be the starter relay..
Feb 01, 2009 | 1995 Chevrolet Blazer
Snowmobile yamaha enticer manual for carberater
why don't you just check the compression if it's low fix it check the carbs make sure it works and make sure you bearing are goo your clutch your vbelt your track and that you have a the boggy wheels on it
Jan 11, 2009 | Yamaha YHT-340 System
Yamaha YHT-340 System Logo
419 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
