Question about Sony Handycam DCR-HC90 Mini DV Digital Camcorder
DCR-HC90 thinks unlocked tapes are locked.
I have the tabs on my tapes set to "Rec," but with all of them my camera says "the tape is locked" and will not record to them. How can I fix this?
I have the same problem. do you know part to buy there: https://etverkauf.tvs-logistic.de
thanks a lot!
peter
Posted on Jun 11, 2010
  • 169 Answers
The flexwire of the camera at the bottom of the mechanical assembly is already cut..it is need to repair that flexwire or replace the mechanical assembly to sony service center....
Posted on Feb 19, 2008
I Have a Sony DCR-HC90 and I'm having trouble connecting my camera into my mac. I Have a usb cable but the camera won't connect to my computer
USB will only download still photos or movie shorts stored on a card. eg memory stick.
If no card is in the camera then no connection.
If you wish to capture movies stored on the tape, you will require a firewire cable to connect.
Use iMovie to capture the footage or another Mac application like Final Cut if availble on your Mac.
Apr 16, 2011 | Sony Handycam DCR-HC90 Mini DV Digital...
I have not used my handycam for a few months, and now it does not record. Push rec button and nothing happens .The camera will take pics rewind,fast foreward and play but push record and nothing.
The camera wont go in record mode if the tape protection tab is over hole on rear of cass tape, maybe you ought to buy new tape and try again, very little goes wrong on those cameras my friend, there is nothing on market as good these days I can tell you.
Jun 15, 2010 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Tab locked
TRY USING RESET BUTTON ON CAMCORDER .IT WORK FOR ME.
Oct 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony Handycam DCR-PC1E
Yeah ! Your problem is very simple. u can solve it on your own.
If you dont put the tape the comparment closes well and as soon as you pot the tape the compartment does not close , Right ?
The solution is there within ur hands itself.
If you want the compartment to be closed, then simply dont put the tape inside. let it be outside itself. U see, its so easy !
Aug 08, 2008 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony dcr hc21
There is an unlock tab on top of the tape. Switch the tab to the opposite direction.
Jun 10, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
When you press record it ejects the tape
it seems that saftey tab at the outer corner of the cassette is at save mode.just slide the lever towards rec.
Jun 23, 2006 | Sony Handycam DCR-TRV40E Mini DV Digital...
Sony Handycam DCR-HC90 Mini DV Digital Camcorder Logo
366 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
