Question about Kenmore Washing Machines
Will pump, but makes a loud clicking noise when attempting to spin.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
If the rubber center piece is destroyed, the clicking may be the prongs hitting each other.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Feb 01, 2010
Rumble on spin
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Feb 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Noise as is spins
Feb 24, 2014 | Frigidaire FTF2140FS Front Load Washer 10...
During spin cycle loud clunking noise
Feb 16, 2014 | Frigidaire GLTF1670A Front Load Washer
Machine makes noise on spin cycle
Feb 15, 2014 | Frigidaire Washing Machines
Replace bearing and outer tub
Feb 13, 2014 | Frigidaire Washing Machines
Spinning cycle sounds rough
Feb 12, 2014 | Frigidaire ATF6000ES Front Load Washer
Thumping and banging during the high speed spin cycle
Feb 08, 2014 | Frigidaire Washing Machines
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
My washer is making a loud, clicking noise
One of them underwire garments could be stuck in the pump and eating a hole into it.You should take the cover off and take a look at it in motion without the case.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
47 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
