We want to remove a non-functioning outside compressor of a Mr.Slim split unit system. Accordng to the installation manual it is either the MS12/15E MSH12/15E model. How do you disconnect and cap off the lines? Is there any special equipment, like a vacuum pump, required? What type of caps can we use?
  • aschenbrk001 Feb 01, 2010
    Hello, I want to clarify: The unit has not been in use for 10 years and the compressor is not working. Is it possible that some refrigerant is still in the unit? Would it be safe to simpy disconnect it? Or would there be a device where one can check if the refrigerant is still in there and if not then simply disconnect it? Would there be a hazard involved by simply disconnecting it? Thanks
  • aschenbrk001 Feb 02, 2010
    Thanks
    President:
  • 1,218 Answers
Good day, You will need more than a vacuum pump. If you live in the states you will need a refrigerant recovery unit. It recovers refrigerant and stores it in a ODOT tank for disposal. Unless your licensed you have no access to a device such as this. I would suggest you call a licensed refrigeration or AC company to perform the operation. They would be able to cap any connections at the same time.
Posted on Feb 01, 2010
  • John Hall Feb 02, 2010
    Good day,
    As a licensed refrigeration service tech, I am required to explain the EPA'S regulations.
    However, The law does not,as far as I know, apply to individuals when dealing with this issue.
    I have never known an individual getting into a problem doing what you want.
    I don't know whether the lines are to be just cut, or are in fact fittings.
    If fittings, any commercial refrigeration supply house can supply them. (They are not the same size usually as plumbing fittings. If simple copper, just pinch them shut, and use duct tape, or solder them shut.
    I'm assuming you plan no future with this unit.
    Good,
    however, there is the possibility that there is still some pressure in the system. Proceed with caution. Most units have a device similar to a tire stem. You can depress the pin first to check for pressure, otherwise you would need to loosen a line and wear protective gear, including glasses.
Icing up outside. no heat inside
Isolate unit to defrost out door unit,
Once defrosted run unit ensuring heat from unit inside and fans are running outside,
if fans and compressor are running and there is next to no heat inside coming from indoor unit this is a common sign of a refrigerant shortage in system and this may cause outdoor unit to freeze up
Jan 24, 2016 | Mitsubishi Electric Mr Slim E12C26426...
My split ducting unit cools when started only
Is your outside coil dirty wash it this may help. Sounds like your head pressure is getting to high and the compressor is kicking out on thermal overload.
Sep 18, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Pressure readings
the metering device is in the outside unit on mini splits that is why the liquid line sweats. pressure reading depend on load high load high readings i would shoot for arount a 40f suction saturation temp
Jun 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Split system outside unit won't come on for cooling, only heating
Check your filters, dog hair and lack of maintenance will definitely burden the cooling mode of the Mr Slim units.
Aug 22, 2009 | Mitsubishi Heating & Cooling
Mr Slim split system with no display on remote control or unit display.
Mitsubishi Mr slim comes with no diplay on the indoor unit but there is small display on th eremote unit.for further help kindly send your air conditones complete model
Jul 09, 2009 | Heating & Cooling
Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
No heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Nov 13, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
