Question about LG 42LC2D 42 in. LCD HDTV
LG 42in plasma - Green dots on HDMI channel
I have an LG 42in Plasma HDTV, and for some wierd reason, when ever i switch it over to the HDMI channels, small green, pixelated, random dispersed clumps of green spots appear on the tv screen. The problem seems to correct its self after the TV has been on for a while but i really dont know what is causing the green dots to appear. It doesnt occur when i watch digital television or on an other channels apart from HDMI 1 & 2. Can anybody shed anylight on the situation?
Cheers, Will
  • 1 more comment
  • Niels Gj?l Johansen
    Niels Gj?l Johansen Mar 18, 2008
    Hi
    I've got 42PT85 from LG aswell, and I experience the exact same problems. I've just contacted their hotline, and they will send a technician to try and ort out the problem.My problems started on HDMI2, but now it's on both HDMI's
    I had a loudspeaker placed on top of one of my HDMI cables, and thought that was the reeason - but nope - removing did'nt help.
    also tried exchanging the cables without any luck.
    Apart from that I'm satisfied with the tv.
  • Anonymous Jun 30, 2008
    SAME PROBLEM... GETTING WORSE.
  • Anonymous Dec 03, 2008
    i have the LG 42PC56 screen and have the same problem your describing. I only get them when running my HTPC through HDMI 1 or 2 or the PC input. DVB seems fine along with other HDMI devices. Its really an annoyance.
Cheers mate, is there anywhere you cold think of that would be able to deal with these kind of problems at all?
Posted on Feb 20, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
The diffusion is slightly out of adjusment. This timing adjustment is difficult and on a single scan LG plasma the proper operation requires voltage settings first, then a scope to finalize the adjustment. I have good luck with this alignment by eye but have had alot of practice. This will require taking the back off and a person with the technical background to set this alignment properly. Sorry no easy fix.
Posted on Feb 19, 2008
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Not widescreen on regular channels only hd channels
Sounds like a setting in the cable or satellite box or how you have the TV connected. Using HDMI it should resize automatically, but again it could be a simple setting in the cable/satellite box or in the TV itself.
Mar 24, 2014 | LG 50PG20 50 in. Plasma HDTV
LG Plasma TV Buzzez when HDMI cable is connected, not all the time just randomly. different stations different times, why
HDMI is very prone to audio problems--the advantages of HDMI are just one cable combines all---Issue if using a box or only on certain channels could be coming from the box if used.
If using component connections and no problem at all-it likely is not the set.
HDMI sets sometimes require a software/firmware update to resolve issues here--if random it is going to be hard to resolve.
Apr 16, 2012 | LG 50PC5DC 50 in. Plasma HDTV
HD channels look terrible
You may not have the resolution set to hd even though you are on the channel. Confirm that you are using hd cable and your set is displaying 720p or greater. This will sometimes pop up on the screen when you tune to a hd channel. it sounds like you are on 480 i or p. good luck
May 04, 2010 | LG 42PX5D 42 in. Plasma HDTV
LG Plasma Green Screen
First thing to do would be to check your cables feeding into the TV. If you're using component cables, it's likely that your red and blue cables have come unplugged and all you're feeding to the TV is the green signal. However, if you're using a different set of cables or they're all plugged in properly, I would first suggest swapping out the cable for a new one. In newer televisions, such as yours, each of the colours is transferred through separate channels regardless of the type of cable used.
If either of those don't help then I'm afraid you've got an issue with the charging of the phosphorus gas itself, either it's not receiving the power correctly or some of the gases are remaining inert and not charging. If you're at that stage, you need to seek technical assistance from a service depot or LG.
Best of luck!
Dec 08, 2009 | LG 60PC1DC 60 in. Plasma HDTV
Green screen on Lg 50" plasma TV, you can hear the channel but it is a full green screen
I am having the exact same problem with my LG 50". It's two weeks old. Has anyone found a solution?
Oct 28, 2009 | LG 50PX5D 50 in. Plasma HDTV
I have a LG 42PC5D plasma TV and there's a sound delay on all channels. I'm using a HDMI cable from a Comcast DVR convertor directly to the TV. Is there a firmware update that's needed? If so, how do I...
firmware is mostly used by commercial TV´s, try using your TV with other device or an aerial antenna.
I believe the problem is your comcast DVR convertor.
May 16, 2009 | LG 42PX5D 42 in. Plasma HDTV
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Feb 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
42 plasma tv no picture but have sound
Try pluging in the euro connecters in tight on the back of the set or in some cases HDMI cables
Jan 30, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
1,479 people viewed this question
