Question about Ovens
I need a manual for a Welbilt Confection Toaster Oven
I have manual for welbilt model cv6311
Posted on Feb 02, 2010
  • Diane Pflug
    Diane Pflug Aug 25, 2010
    ask here: manualfox.com/link/welbilt.htm
    Problem Solver:
  • 5 Answers
There is a similar item: the Elite Cuisine Convection Oven With Rotisserie, Grill & Griddle and Steamer. I downloaded the manual from this site: http://pdfstream.manualsonline.com/c/cb4ba73b-938a-47cf-84e9-5ae1cbd777f0.pdf and finally now know how to use all the various pieces that came with the Welbilt Convection & Toaster Oven plus Griddle & Rotisserie (CV6311) that I bought at a yard sale.
Posted on Jun 13, 2017
    New Friend:
I have a Welbilt CV 6311 and the manual in excellent condition.
albertebbs@sbcglobal.net
Posted on Jul 28, 2015
I have a Welbilt Convection Toaster oven with rotisserie model # CV6311 and I'm missing the rotisserie spit. Do you know where I can get another one?
It's quite difficult to get a replacement rotisserie spit. I suggest to a web-link of a supplier, where you may find the spare rotisserie spit as per your model number.
You need to contact with them at " http://www.gehousewares.com/Customer_Assistance.aspx". Here you will find how to order a spare part. Contact with them and follow the instruction.
Hope this will help you.
Jul 08, 2011 | Ovens
Co confection oven door will not stay close . model number 1418342L
Try cleaning and removing the door, it may be causing the hinges some problem inside .
hope this is helpful
John
May 31, 2011 | Ovens
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Need manual toaster oven with 9-in pizza stone kenmore
go to this web site-http://www.sears.com/shc/s/p_10153_12605_00880009000P
there is a phone # or e-mail address to choose from. Just tell them what you need---you will need your model #
Sep 17, 2010 | Ovens
Turbochef toaster oven cc temp on warm up only 265 deg ir 465
if your a commerical oven tech then just call 1-800-90turbo are you getting an error code i would probably check the convection circuit first starting with the blower motor and checking if the Windings are ok
Dec 12, 2009 | TurboChef TORNADO Electric Oven
GE Profile Convection Problem
with GE
SHORTED OVEN SENSOR CIRCUIT
if your comfortable taking the range out of the box, it is a pretty easy repair. The oven sensor is a small tube in the range that "sences" temp.
although it could be the erc, its more than likely the sonsor itself.
it is on the back wall and has to be unplugged from the back to be removed
there are two screws that hold it on the back wall
put the new one in and you should be ready to go
goto appliancepartspros.com
type in your modle number and look in the cavity section
your looking for the oven sensor
they usually run around 20-30 dollars
Oct 17, 2009 | GE Profile 30" Built-In Single Electric...
Oven gets too hot
Thermostat needs to be replaced.
Apr 10, 2008 | Ovens
Ovens Logo
265 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
