Question about Toshiba 27HLV95 Television
DVD disc inside. Combo does'nt recognyze it. can't
DVD disc inside. Combo does'nt recognyze it. I can't extract it or play it. What can I do?
Turn off system. Unplug power cord for about 3 minutes to reset it.Then plug cord and turn TV/DVD on. After this you can eject the disc.
Posted on Feb 04, 2010
  • Scott Jones
    Scott Jones Nov 02, 2015
    Thnx. Had same problem and that worked!! It would cost more to fix it than to replace at this point. Thnx again!!
I have a JVC TV/DVD combo and the DVD stopped working
This is a common problem with DVDs. You must not leave them idle for such long periods. Second, you must always leave a disc inside the player. It protects the optical lance from dust. There may be some dust deposit on the lance or the loading rubber belt may have gone lose or the spindle motor which rotates the disc might have gone slow. But to solve this problem you will need a qualified technician. Good luck.
Jan 08, 2014 | JVC LT-32D210 32 in. LCD TV/DVD Combo
20F510TD
eject the cd tray and use canned air to clean the inside of the cd/dvd unit, just use stick the nozzle near the opening and give it a through dusting. after that, run a cleaning disc through it a few times.
if that doesn't clear up the problem, the dvd player will need to be serviced, most likely either a lens replacement or re-alignment.
hope this helps,
trin
Nov 20, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
DVD player restarts after only two minutes of playing.
Check its mechanism for proper movment. If tracking movment is not correct, this type of fault can occur.
Apr 15, 2012 | GoVideo Go Video DVD/VCR Combo
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Dvd got stuck.it plays but wont come out..after several trial nothing work out..
remove lid on dvd and turn timing gears untill disc ejects.
May 24, 2010 | Televison & Video
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Playing dvd's
Inside the Control Panels, look for System. Double-click System and choose Device Manager. Inside Device Manager, find the CD/DVD and "Uninstall" the device. Restart the computer and let it re-load the driver. This might help. You can also try a CD/DVD laser lens cleaner.
Nov 12, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
Televison & Video Logo
129 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
