Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
My hard drive just stopped working all of a sudden
My hard drive was fine and then It just stopped working. My computer doesn't recognize it all. I tried it on another computers and got the same problem. Nothing. The light lights up so I know that it isnt the power. I have alot of stuff on here. what can
  • 3 more comments
  • Anonymous Mar 07, 2008
    Same damn problem!!!
  • JASONG35 Nov 25, 2008
    HELP I HAVE THE SAME PROBLEM AS THE GUY ABOVE
  • dtphotograph Dec 22, 2008
    same here.
    Hard drive shows a steady white light...but light used to fade in and out.
    Help!
  • ty23 Jan 08, 2009
    My problem is the same the computer sees it and powers it. When I remove it the PC even sees it has been removed. I have searched areas of support and really need to get access to my external HD. anyone have any advice?
    Thank you,
    Tyler
  • stevec16 Jan 20, 2009
    Same with me - d-e-a-d, dead. My IT guy says it is a mechanical failure and it might cost more than $2,000 to retrieve the data, IF it can be recovered. I did as the tag line on the box instructed: "Put your life on it." And I got screwed.
    Problem Solver:
  • 5 Answers
Search around on this site for MyBook 500GB problems. I've responded to a couple, but it amazes me that lots of people, including myself, has a failed unit. Mine lasted 1.5 yrs and failure is caused by burned chip pins on the drive controller. Seems likely to be a heat issue. More info about what I did; see my other posts.
Posted on Dec 09, 2008
The HD suddenly stops getting recognized by the laptop, in the middle of any action.
Sounds like a conflict. Disconnect any other USB attached devices while running HD. Worked for me with same problem.
Aug 26, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
Acomdata external hard USB hard drive model HD160UE5-72 worked fine then suddenly the device was not recognized. Reboot with unit powerered up and the device is not detected. Blue LED is on, tried...
Either the hard drive is bogus or the electronics of the external adapter is the culprit. Take out drive and hookl directly to mo bo as a secondary drive. If recognized drive is ok and the box is at fault.
Aug 25, 2017 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My hard drive suddenly started beeping and stopped working
Your drive has failed. to try to get back some of your items put the drive in the freezer for a day. the chill will make the heads condense enough for about 3 hours of use for emergency backup.
Nov 07, 2009 | Hitachi 500GB External USB 2.0 Hard Drive
I have a 250GB Buffalo Turbo USB Hardrive. Until today it was working fine. Now suddenly it says USB Driver not recognized. Whats the problem?
Try to insert it to the other usb ports and see if it works fine. If it doesn't, then probably there is a problem with it. But try to insert other usb devices in the usb ports of your computer, if it does'nt recognize also then the problem is in your usb ports.
Oct 30, 2009 | Buffalo Technology 250GB MINISTATION TURBO...
Sony drx820 suddenly not recognized by computer
Does the tray open for you? Re-boot the computer and go into the BIOS and see if it is listed by the BIOS. Did you accidentally remove the hardware? Go into the control panel and add new hardware and see if it detects the drive and re-installs it. Otherwise the drive might have stopped working.
Sep 13, 2009 | Sony Computers & Internet
WD2500JB hard drive not recognize. Stop working
It's possible that the controller board on the underside of the drive has failed.
Mar 21, 2009 | Western Digital Caviar SE WD2500JB 250 GB...
Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
Jan 08, 2009 | Maxtor OneTouch III 500 GB Hard Drive
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
1,670 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
