Question about Dell Latitude D600 Notebook
Computer boots up fine, after about a min, screen flickers and goes off. Can close the screen and open again to have the image last for another minute. Checked all the power and screensaver settings all are currently off of set at 1 hour.
Sounds like a problem in the LCD assembly - either the fluorescent tube, or the inverter. You can get a replacement screen on ebay for about $50-100, they are not too difficult to replace. Dell has detailed service instructions available on their site. Good luck!
Posted on Feb 01, 2010
Testimonial: "Thanks for the information. I currently cheated and am using a KVM switch and sharing the display with my desktop."
Lenovo screen lines
Its a sign of bad RAM. Something it happen because of dust in the ram or something its indicate that ram is going to expire. If it is possible so I will recommend you to open your computer and clean the ram and try it again. If the problem will still present then you have to change your RAM.
Oct 17, 2013 | Computers & Internet
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
Sleep mode
Reinstall the Power management . Install the updated graphics drivers
Aug 07, 2013 | HP Compaq Presario CQ60-249US Notebook
Laptop screen flickering
The video inverter may be failing, BUT...
More than likely the backlight is failing. If you can still see a VERY faint image on the screen this is almost certainly the problem.This is a very difficult fix. I recommend a replacement LCD.
It MIGHT be a bad lcd cable. With the laptop on, slowly open it from closed to open and back again and see if there is a position where the laptop screen does not flicker or turn off, [or if it does turn off if it turns back on.
If the screen goes COMPLETELY black then your GPU is failing.
Feb 21, 2012 | HP Computers & Internet
Flickering in half screen after 1 to 2 hours
Probably caused by a power supply nearing its death.
Try to verify this by placing a portable fan to the side of the set with airflow directed at the vented sides.
If this lengthens the operating time, there is a good chance that some minor components in the main supply have developed low values of capacitance and higher losses which worsen with warmth.
Listen closely at the vents with the sound turned down to attempt to detect a squealing sound while the TV is in its failure mode; if you find this, it is also a sign of power supply trying to die.
A tech equipped with a capacitance meter that measures losses at the same time, could find and replace the weakened parts without a whole lot of labor and little cost for parts.
Nov 26, 2009 | Philips Televison & Video
Sumsung 930b goes dim,and flickers after about 3 min.
This sounds like the inverter has gone bad. If the bulb were bad only, you would see a faint image on the screen with a flashlight.
The problem is on this monitor, it will probably cost about $100 or so to take it to a shop to get it fixed, and that is nearing the cost of a new monitor.
If you are a little bit handy, and can disassemble the monitor, you can replace the inverter. The hardest thing about this, is getting the monitor faceplate open. Just use something firm and softer, such as a nylon spudger (this is something you can find online) or you can carefully use a thin scredriver. You just have to be careful, those cases are really tight.
Here is a good guide for general ideas on how it is done.
http://www.instructables.com/id/Replace-LCD-Backlight-Inverter-on-Any-Monitor-for-/
Paul
Apr 09, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Lower screen flickering
ITS NOT HARD 2 TAKE IT 2 A REPAIR SHOP
Jul 27, 2008 | Nintendo DS Lite Console
LCD flashes and flickers, partial display of bootup and then black screen
Try the following:
Sometimes when you press and hold the corners of the LCD area (not on the LCD itself, but on the frame), and see if it gives you a picture (or at least flickers when you do so).
My opinion is that your LCD could need rewiring or replacing.
Dec 15, 2007 | Dell Latitude D505 Notebook
Dell Latitude D600 Notebook Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
