Canon gp 200
Facing a problem of printer of canon gp 200-225??
When i power on the machine having copy, fax * print, my print option just say wait & doesnot process further
cant understand wats the problem??
can anyone help me plsss
waitng for help
  • 1 more comment
  • Naveen lunia
    Naveen lunia Feb 25, 2008
    can u tell me in detail wats the probs
  • Anonymous Aug 15, 2008
    I just went through the same problem. Its either the printer board is shot, or the hard drive is puked. I needed to replace the whole assembly with a used board to get it up and running again. I fu'd by formating the harddrive. Canon loads all the base drivers on the hard drive but won't release the firmware as they consider it "proprietary". Funny how the don't support the machine anymore but the software is forboden.
  • vin355705 May 04, 2009
    have a prbolem with a Canon Gp225 when on the machines i get display pls switch main off or on E000
What the canon gp 225 ip address?
Posted on Jun 12, 2008
    Genius:
  • 3,587 Answers
Suggest you reload drivers.
Posted on Feb 19, 2008
DOES THE MACHINE HAVE FAX CAPABILITIES? DO YOU
No. They have print,scan and copy capabilities but no fax option is avail.
Dec 17, 2009 | Canon imageRUNNER 5000 Copier
Incoming faxes do not print, fax report reads 'power fail' and diplay reads 'low memory' - Can you help?
First, does the machine print normally from a computer or when making copies?
If so, then most probably you have enabled a private receive fax mode. In this mode, faxes are not printed immediately upon receipt (to prevent unauthorized people to read them), but are stored in memory, waiting for an authorized person to come and print them, providing a PIN (password).
To print the faxes stored in memory, do the following:
- press FaxMenu
- using arrow buttons select "receive"
- press OK
- using arrow buttons select "print faxes"
- press OK
- using the alphanumeric keypad enter the PIN/password and press OK
THe previously received faxes should print..
SOmeone must have turned this option on, so ask that person what he/she entered as the PIN.
Dec 04, 2009 | HP Laserjet CM 1312NFI Color Printer
What is error code 300 for Canon MX310
Error Code 300 is displayed.
1) Cause : The machine not ready.
Action : Confirm that the power lamp is green.
If the power lamp is off, turn the machine on.
While the power lamp is flashing green, the machine is initializing. Wait until the power lamp stops flashing and remains green.
If the Alarm lamp is orange, an error may have occured on the machine.
2) Cause : Machine is not connected properly.
Action : Make sure that the USB cable is securely plugged into the machine and the computer.
* if you are using a relay device such as USB hub, disconnect it, connect the machine directly to the computer, and try printing again. If printing start normally, there is a problem with the relay device.
Consult the reseller of the relay device for details.
* There could be a problem with the USB cable. Replace the USB cable and try printing again.
3) Cause : Your machine is not selected in Printer on the Print dialog box.
Action : Select your machine's name in the printer on the Print dialog box.
If your machine name doesnot appear in Printer, follow the procedurebelow to check that the driver for your machine is installed on your computer.
a) Select Print & Fax Preferences in Printer.
In Mac OS X. v.10.2.8 or 190.3.x, select Edit Printer List in Printer.
b) Check that your machine's name is displayed in the list of printers and that the check is selected.
In Mac OS.X v.10.2.8, check that your machine;s name is displayed in printer list.
c) If your machine's name is not displayed, click Add(+) to add the machine. If you cannot add the machine, follow the procedure described in youe setup sheet to reinstall the MP drivers.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Shaded Background on the paper when making copies.
You need to clean the rollers and possibly change the ink cartridge.
Sep 05, 2009 | Canon GP-200 All-In-One Printer
Can't access system settings on Canon imagerunner 400s
Turn off the main power switch, and
disconnect the power cord.
Remove the copyboard glass; then,
remove the screw, and detach the small
cover from the IP cover.
remove the remove all eprom dccon ram
& insert again & start the machine.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
"waiting for report" /won't copy
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
Apr 22, 2008 | Canon PIXMA MX310 All-In-One Printer
562 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
