Question about Intel Motherboard
MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
I went to start up my computer and had no monitor! Put a old monitor into VGA onboard, worked fine. Went to uninstall my graphics card (in PCI-E), found no reference to it in drivers. Reinstalled drivers, still nothing. Took card out, booted, didn't say anything about hardware being removed. Put card back in, rebooted, didn't say anything about new hardware. Went into BIOS and re-selected PCI Express over onboard graphics, saved and exited. Still nothing. It's almost as if the motherboard doesn't even know that it has a PCI-E slot anymore. No power to it or anyting. Graphics card and monitor worked fine for about 1 yr now, not sure what went wrong. So, is there a way to diagnose a PCI-E slot for power/info. if I do not have a second PCI-E card to stick in there? Other than BIOS "PCI Express/Onboard" option is there any other places that I could FORCE the motherboard to look at the PCI-E?
  • Anonymous Oct 05, 2008
    I tried to install an ATI 2400 HD Pro on my computer using the PCI-Express slot. It worked fine until I upgraded to Vista, then it was like the card didn't exist anymore. So I downgraded back to XP, and still no card. I am now stuck with these crappy onboard graphics and there is nothing I can do about it.
Msi k8ngm2 h motherboard driver where are showing me
Posted on May 30, 2008
  • 33 Answers
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Posted on Feb 19, 2008
I have an Emachines T6532. The screen keeps "glitching" out on me. Any idea what might be causing this, or how to fix it??
http://i2.photobucket.com/albums/y47/beetle665/IMG_4829.jpg
DUDE! You can't post pictures like THAT!
Put sum clothes on that girl!
-> OH,....I'M JUST KIDDING! <-
1) Check the monitor cable.
If attached to the monitor, use the monitor, and cable on a WORKING computer. Same thing? Need a different monitor.
Use a KNOWN to be working monitor cable, if detachable; on your computer.
No? Monitor cable is good?
Go on.
2) We are dealing with a graphics problem.
Next in line is the graphics chipset.
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard. Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
Clicking on the photo shows a MUCH better view.
You have two white PCI slots at the Bottom, (PCI1 and PCI2), and a white longer PCI Express x16 slot above them.
[The shorter white slot above the long white PCI Express x16 slot, is a PCI Express x1 slot)
Integrated Graphics is also known as OnBoard Graphics.
A term that seldom seems used anymore. Too bad because it explains better.
ON the motherBOARD.
The graphics chipset is part of the motherboard chipset, which is Soldered TO the motherboard.
If the OnBoard Graphics of the motherboard is suspected to be bad, the tech will then use a graphics card; and bypass the Integrated/OnBoard graphics.
You have your choice of using one of the white PCI slots, if available; or the white PCI Express x16 slot.
Posting in case you have a graphics card sitting around.
Anti-Static Procedures are FOLLOWED, with your unplugged from power computer. The graphics card is physically installed.
Monitor attached to graphics card.
When you turn the computer on, the graphics won't be perfect. This is because THE graphics drivers for THAT graphics card; has not been installed yet.
Will sort of look 'Fred Flintstone-sih'
(Color quality will probably be set at 8 bit, instead of 16-bit; and Screen Resolution will be wrong)
That's OK. Right now you are just trying to get graphics.
I'll guide you through installing the drivers.
Post back in a Comment.
Regards,
joecoolvette
Mar 12, 2013 | eMachines Computers & Internet
Adding discrete graphics card to p6stp-fl
!O_O!
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds. Let go. (HAS to be 10. Count)
Do this same procedure TWO more times.
(IF the Power On LED flashes for a second, keep repeating until it doesn't)
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup parameters back to the factory default settings.
3) FOLLOWING Anti-Static Precautions remove the graphics card.
Plug the monitor back into the Integrated (OnBoard) graphics, of the motherboard. (VGA connector)
4) Plug the computer back into power. WAIT 1 minute, turn the computer on.
5) When Windows has loaded wait a couple of minutes, then take that graphics card's Installation (CD) Disk, and put it in the optical drive.
If the disk doesn't start loading after 10 seconds, go to My Computer, and double-click on the drive letter, next to the optical drive, the Installation Disk is in.
When asked choose all software. Nvidia Control Panel, and drivers.
Your computer will keep on using the Integrated (OnBoard) drivers, for graphics. It will Not use the drivers, and software you are installing now, until the graphics card is physically installed.
Install all software. If you are asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off normally.
(Start > Turn Off Computer > Turn Off)
6) Unplug from power, follow Anti-Static Precautions.
Unplug the monitor from the motherboard. Physically install the graphics card.
Plug the monitor into the graphics card. Close the computer case.
7) Plug into power. WAIT 1 minute, turn the computer on.
You may have to go into Nvidia Control Panel, and set the correct parameters for your monitor. (Screen Resolution / Color quality )
Clear CMOS Error Codes, and reset BIOS Setup back to factory settings doesn't work?
You get to go back into BIOS Setup, and set the submenu you changed, (Or submenu's), back to the factory standard setting.
(F6?)
You are trying to use the OnBoard graphics drivers for the -> graphics card. This = NO.
You need THE drivers for the graphics card installed F-I-R-S-T.
(OnBoard. ON the motherBOARD.
Used to be used for Integrated Graphics.
Makes it easier to understand if you use OnBoard Graphics )
Why?
When a device, (In this case a graphics adapter card), is installed, Windows 'breaks it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = No.
You need THE drivers already installed. Windows looks to see what device is installed, then finds THE drivers needed.
Regards,
joecoolvette
Sep 13, 2012 | EliteGroup P6STP-FL Motherboard
No video in onboard plugin
If the motherboard has an onboard VGA output - try that. But first remove the plugin video card from the computer and then check the onboard VGA output.
Nov 02, 2010 | MSI 7207-090(K8NGM2-NBP) Socket...
MSI mobo powers up, but no signal to monitor.
i hate to tell you this but it seems your pci or in your case agp exp.slot is most likely melfunctioning if your card works on another computer then that may be your problem one thing you can try is take the mobo out and let it sit for a few days or call msi them selves and they may replace it for you for free they are good about that i have the k8n neo4 with a 7950 1g pci.e with same problem and thats my pci e not working
Mar 15, 2010 | MSI K8N Neo4-F Motherboard
When I plug my monitor into my video card i get "no input signal" yet if i plug it into the onboard slot it works.could my PCI-E slot be bad?
Did you add a video card? If you have an AGP slot, it is best to put the video card in it. If so you need to go into the Device manager. Remove, disable or uninstall the onboard VGA driver. Go ahead and remove the PCI video card driver as well. Power down PC. Make sure monitor is hooked up to the Video Card, not onboard VGA. Power on PC. When Windows loads, it should detect the VGA card first, but if it detects the onboard first, ignore and don't setup onboard first. When Windows detects the card, load the necessary drivers when prompted. There is no need to reinstall the onboard driver for the video unless you wish to hook up two monitors.
Nov 08, 2009 | HP w1907 LCD Monitor
The light on monitor stays yellow
If your PC has started HDD flashing and there is power to the monitor this means that the video card has not told the monitor to display, its kind of like in standby you can get this if the onboard VGA is faulty.
If you have another basic VGA card insert this into a spare PCI slot while the PC is off and plug the monitor into this instead if this works your monitor is fine and looks like your VGA on the mobo is trashed, just buy decent 512MB PCI or AGP video card and use this setup instead.
Its also good idea to disable the on board VGA in the BIOS.
LOL
Sep 26, 2009 | Compaq Presario 5000 PC Desktop
No signal problem with xfx 9400gt fatal1ty
Check for bios jumper set for normal operation, check for onboard vga jumper set for pci or external video.
Jul 14, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
ECS 945GCT-M/1333 System Board
I can see you getting an error with pci.sys but not with pcy.sys.
Did a full system scan in a working WinXP Pro & found not such animal within the system or regestry. After looking through microsoft I did come across pci.sys and what may creat such an error. I would point to your onboard VGA. If intergrated into the board as I suspect. It is a pci device. During install windows found something wrong with it hence your error & blue screen. Suggest using your PCIE card & set bios to same disabling the VGA. Your install should no longer fail.
Good luck & please vote!
Jan 12, 2008 | ECS 945GZT-M (V1.0) Motherboard
Gigabyte onboard vga is not default... no pci card
What you can do here is remove the Battery on your mobo. This will reset the CMOS and then you should be able to access your CMOS as usual. :)
Dec 25, 2007 | Intel Motherboard
Intel Motherboard Logo
1,189 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
