Question about Honda 8 HP Engine
I have a honda gx160 motor it starts and runs but its knocking what is wrong and what should i do?
    Problem Solver:
  • 15 Answers
Is the air filter dirty? With the bowl as the lowest part of the fuel system, any dirt or water will wind up here. Turn off the fuel valve, or drain the gas tank, then place a rag under the bowl to catch the gas that will run out. Loosen the "nut" that holds the bowl on, and after the gas has stopped draining remove the nut and bowl, but do not let the float swing all the way down! Wipe out the bowl. The "nut" usually contains 1 or 2 very small passages, soak in (or spray with) carb cleaner and use a wire bread-tie or other soft wire to poke out the holes. Blow out with compressed air, if available. Put the bowl back on and try to start it. If it still will not start, it needs a good soaking and a rebuild kit. Take a look at following link to see more solution to different small engine problems. http://solosmallengine.blogspot.com/
Posted on Jun 08, 2012
    Top Expert:
  • Honda Master
  • 11,211 Answers
Either rod knock where engine rebuild will be needed or retaining bolts are loose and motor is bouncing check bolts at base
Posted on Feb 01, 2010
Honda gx160 5.5 hp getting too hot
On most of these engines since they are air cooled you need to have all of the metal shielding that came with the engine on it. These help direct the flow of air from the flywheel fins to cool the engine. You may have to remove the metal shields and clean the fins if you have an older motor that has been run in really dirty areas. If air can't flow between the fins it can't cool. I will mention oil level just because oil also helps cool the engine how ever most of these engines will not run if the oil is low due to an oil pressure switch that prevents it from running if the oil level is too low.
Dec 30, 2014 | 5.5 HP GX160 Engine
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Honda gx160 will not run on idle
There are a few things i can think of that would cause that problem. #1 clean out the carb, some times when an engine sits for a little while the gas will gum up in the carb. #2 check the tuning on the carb, It is possible that the idle screw needs a bit of adjustment. #3 The gas could have gone bad. Again if it sits for a while and the gas cap doesn't seal properly your gas will go bad in a hurry.
Hope this helps.
Sep 20, 2013 | 5.5 HP GX160 Engine
Honda gx160 qh26 wont start, backfires thorugh exhst, new plug, re&re carb,valves in. .006 ex. .008 , sos please
The Honda GX160 is a single-cylinder multipurpose engine, so it doesn't have a timing belt, fuel filter, or any other wires other than the single spark plug wire and a ground. I'm having the same trouble with my Honda GX160. Spark is good, compression feels a bit lacking though, I haven't measured it. I've heard that the carburetor might be the cause, either needing to be cleaned or replaced as a whole. Dunking it in CLR works wonders, and if that doesn't work, you could probably find a new carburetor pretty cheaply.
Mar 19, 2013 | Cars & Trucks
Honda GX160 firepump runs good than dies starts first pull after and repeats
Check that the fuel tank is venting properly, sounds as though the tank is not venting therefore creating a vacuum that the carburetor cannot over come. Try running the engine with the fuel cap loose to see if that alows the engine to continue to run.
Dec 16, 2012 | 5.5hp 6:1 Gear Ratio GX160 Engine
Honda GX160 starts runs dies
How about the carb was it cleaned ???? It's definitely a fuel issue
Why does my honda gx160 start and run for minute or two then cut off. Will restart
Hi, check the oil level. If low the oil guardian is cutting the spark. Regards Phil.
Aug 19, 2012 | 5.5 HP GX160 Engine
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Honda 8 HP Engine Logo
693 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
