Question about Whirlpool Washing Machines
Won't stop filling - Whirlpool Washing Machines
  • Whirlpool Master
  • 3,051 Answers
Hello there :
please try these solutions that i have provided below
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Feb 01, 2010
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
Won't stop filling with water Model # WDSR2080G3WW
Does it stop filling if you stop it at the dial or unplug it?
Nov 06, 2012 | Washing Machines
Kenmore washer model #111092581200 won't stop filling and won't agitate
Please recheck that model number. It is coming up as a microwave.
Oct 31, 2012 | Washing Machines
Whdre526e1ww won't stop filling
Does the washer continue to fill if you turn the dial to the off position or does it keep filling when starting a load?
Oct 17, 2012 | GE WDSR2080D Top Load Washer
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Water won't stop filling
If the water still flows in when the machine is off the inlet solenoid is faulty, if when you push start it fills and keeps filling then the problem will be with either the electronics or the pressure switch.
You really need to get someone who has experience with whirlpool machines to look at it for you.
Mar 08, 2012 | Whirlpool Washing Machines
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
Mar 08, 2012 | Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
